Old 05-29-2023, 02:47 PM
Dave73TA's Avatar
Dave73TA Dave73TA is offline
Default Oil pan gasket
I have a question about oil pan gasket .At the rear of the motor there à 3 tab black gasket .In the kit it comes with à cork gasket .Also .Do i use both gaskets back there .Or just the black 3 tab .And the kit came with à 1 inch round white plastic seal Don t know where that goes .?Thank you .
Old 05-29-2023, 08:39 PM
The cork gasket is for an earlier style oil pan. Usually the pan gasket comes with 3 different gaskets. 2 rubber and 1 cork. I have no idea what the plastic seal is. could to post picture?
Old 05-29-2023, 08:53 PM
rolling money pits's Avatar
rolling money pits rolling money pits is offline
Drain plug?
costs too much
Old 05-29-2023, 10:10 PM
Dave73TA's Avatar
See if i can post the pic .Could be drain plug .
Old 05-29-2023, 11:33 PM
Gach's Avatar
Gach Gach is offline
Yup drain plug
Old 05-30-2023, 02:52 AM
I don’t think I would be wrong to say that 90% of use prefer to use the cork seal even when the pan we are using has the holes for the rubber seal.
Old 05-30-2023, 03:35 AM
lust4speed's Avatar
The earlier rear main for the cork seal has the deep groove cut in and probably 50% of the height of the cork seal resides in that groove. If the rear main is the later flat style, I'd just use the correct rubber seal with the sails.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
The Following User Says Thank You to lust4speed For This Useful Post:
Old 05-30-2023, 06:48 AM
Dave73TA's Avatar
Thank you everyone .Got it now .The cork strip is for 1970 and earlier .Is what i am getting from this .And drain plug gasket .
Old 05-30-2023, 06:59 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Always use a cork seal and a light coat of Ultra Black. Make sure to get the right thickness gasket. The rubber seal will split and leak like crazy! Clean first with brake clean, lacquer thinner, etc.
The Following 3 Users Say Thank You to JSchmitz For This Useful Post:
Old 05-30-2023, 07:48 AM
Gary H's Avatar
Gary H Gary H is offline
X2 on the above. I always use the cork seal on the seal with the tabs on it. Had much better results over the years with it.
The Following 2 Users Say Thank You to Gary H For This Useful Post:
Old 05-30-2023, 08:38 AM
Dave73TA's Avatar
Thank you .
Old 05-30-2023, 08:41 AM
grivera's Avatar
grivera grivera is offline
Are you saying you use both seals together?
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 05-30-2023, 09:24 AM
78w72 78w72 is offline
x3 on the cork seal even on pans made for the rubber. i had a leak that i thought was a rear main, turned out to be the early poor design 3 prong rubber seal that was leaking, re did the pan gasket using a standard felro gasket but used the cork gasket as MR P body explains here, been pretty much leak free for 7+ years now. the later 5 prong rubber U seal is better than teh eralier one but the cork is much better when installed properly.
https://pontiacstreetperformance.com/psp/Sealit.html
Old 05-30-2023, 11:30 AM
JSchmitz's Avatar
Not together. Cork only. This has been talked to death on here. Do a search if you want more info.
Old 05-30-2023, 02:20 PM
grivera's Avatar
I’m aware of that and agree the cork is better. But the way Gary H worded it wasn’t clear he was suggesting the cork in place of the rubber seal verses in conjunction with
Will Rivera
Old 05-30-2023, 09:52 PM
Dave73TA's Avatar
Yeah kind of did .Put the cork in front of the black 3 tab .Half was on .Going with the cork .Buying the felpro 1814 kit .I ll rtv it let it set for a few . Thanks everyone .
Old 05-30-2023, 09:56 PM
Dave73TA's Avatar
Isn t that the answer .To not use the 3 tab black neoprene seal ..And just use the cork in its place ..
Old 05-31-2023, 05:57 AM
JSchmitz's Avatar
YES! See post #14.
It wouldn't make any sense to use the 3-tab seal in conjunction with anything if it splits right?
To me this is very similar to the SBC intake to block seals. Everyone figured out years ago to just put RTV there.
Old 05-31-2023, 12:01 PM
Dave73TA's Avatar
I kind of glad i messed it up ..I was going to go with the black 3 tab .But it didn t seem good enough .So i added the cork in front of it .Half was. on half wasn t .So was worried .But thanks to all of you .I feel confident in rtv ing the cork on .Thank you everyone ,appreciate it .
Old 06-01-2023, 06:38 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Here is the best way to seal the rear of the pan. Forget any type of rubber seal, they have a BAD habit of squishing out and starting a major oil leak. I cut a custom seal from a piece of 1/4" thick rubber impreganted cork material. It's available on-line.
Then just apply a dab of RTV to the ends, set the pan and not one drop of oil will every get past it.......
ID:	613517   Click image for larger version
