I had a 70 parts car firebird, 350, AT, AC, manual disc. Captain obvious, all 70 up were, thankfully disc.
sounds great
Esquire '74 T/A 455 Y-code SD clone previously on Dawson's Creek: '74 T/A 400 '81 AMC SX/4 '69 FB 350 |
no Pwr Steering no Pwr Brakes And is a 3spd Stick Some real oddballs out there |
It was a special order through Stupka Pontiac in Sharon, PA. Delivery was delayed because of the Camaro quarter panel crack issues which interrupted production at Norwood. Finger pointing went to the UAW strike, but it was really metal stamping problems that held up the 1970 model release, thus creating the 1970 1/2 model year.
The Following User Says Thank You to srmmmm For This Useful Post: | ||
It's great that you've been able to keep your car in the family. I salute your long term commitment.
Carl 1970 Formula 400 |
The Following User Says Thank You to cpu For This Useful Post: | ||
Some good progress has been made on the car the last few months and the upholstery shop is nearly finished with the interior. All that is left are the sail panels and passenger door hard trim. The rear glass has to be redone though as the installer set it too deep in the channel and the sail panels aren't fitting right. The glass installer sent the wrong tech out for the job. He had no experience on "vintage" cars.
Once done though, the exhaust system gets fitted up, the hood put on, shaker scoop assembled and then it's road test time. |
NICE!
Originally a custom interior?
Yes, it's the Esprit model car, equipped with the rally gauge package. I've restored it with 1976 TA suspension and will use a TA shaker hood.
What an awesome story.
My parents bought the `70 Esprit that I have today. It was my moms daily from `70-`87. 350 2bbl,nothing special.
`70 Firebird,Original Owner car Ken French Built Chassis Carlquist Competition Engines IA2 505 Competition CNC Ported Super Chiefs CCE Ported Gustram Twin Dominators from Shaker 455 963 HP `09 Electra Glide Standard. `03 F-350 7.3 6-speed 4x4 Crew Cab Dually. |
The Following User Says Thank You to BDHABT For This Useful Post: | ||
Love the build. Curious if you are running headers or RAIII Exhaust manifolds?
Engine came out great! |
Jon well done!!!
Beautiful car,
I like that you kept it an Esprit, nicely done |
Using Hedman headers. Fit was very good, but I did have to go to a cable conversion on the column gearshift lever.
More visible progress! Hood is on but won't close. Snorkels will have to come off the air cleaner housing to clear the A/C compressor and a hood brace. No real issue since the scoop will be open all the time. Pypes exhaust system tucked up under the car nicely and the body is just about down to the correct ride height. The shop says one more month to go.
The Following 5 Users Say Thank You to srmmmm For This Useful Post: | ||
Looks awesome and great gaps and finish!!!!
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
Love the Coronado Gold and '73 SD455 Formula vibe! Great job!
Dennis |
The Following User Says Thank You to SD455DJ For This Useful Post: | ||
Congrats on finishing your car, looks great! You'll have a blast driving that one around with your built 350. Much respect for sticking with the build until the end!
"Hammer to fit, paint to match" |
#38
Is it a Firebird drop base air cleaner ?
Or the standard GTO / Gprix air cleaner ? The drop base bird units have a big dimple hump at the rear to clear the distributor . If you don't see that feature , its a GTO type. Hood won't shut using those. Car and interior look Great Engine build is definitely impressive |
#39
Truly beautiful. Thanks for sharing the photos and an impressive 350.
#40
The Following 2 Users Say Thank You to srmmmm For This Useful Post: | ||
