Looking for a nice set of 3.23 gears for 8.2. Posi Carrier also. John 330 618-6583
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of! |
I had contacted a major gear maker a while back about doing a new run of 3:23 ratio gear sets. Seems like there is pent up demand for this.
I believe it would have been about $500 per set if they made > 40 sets.
1969 Judge, 4-speed, CR/Parchment, Quasi-Survivor, #'s match - under restoration |
Considering they fit Olds too, 40 sets would be only a gesture.
That is a bit of an investment though...
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
I have a set of 3.23 gears still attached to an open carrier that came out of a 66 GTO if that is what you are looking for. I also have the spider gears and clutches to convert an open carrier to a posi unit.
I will also have a set and carrier coming out of a one owner 70 GTO in the next week or so.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
parts to make an open into a posi?
The Following User Says Thank You to 72pontiac For This Useful Post: | ||
The above pictured clutches & side gears can only be used in the style of posi carrier, they came out of. They cannot be used in a single track carrier.
The round eared factory Eaton clutches are typical to being used in posi carriers for 8 7/8 P series, 8 7/8 MP series, 12 bolt Chevy car or 12 bolt Chevy truck. Different designs of posi side gears were designed to accept that style of clutch, 28, 30, & 31 spline side gears w those regular clutch type sets, as well as governor lock posi units.
Buzzards gotta eat... same as worms. Last edited by 'ol Pinion head; 03-26-2023 at 11:01 AM. |
![]() Quote:
This style of Pontiac 8.2 gear set was introduced in late '69 Birds. Just something to note if trying to EASILY mate with an earlier style 8.2 Pontiac carrier.
Still need these gears.!!
