Firebird 76 relocate oil filter
Anyone done this and have some pics?
I see that butler performance has a kit, but there are options on straight or 45/90 AN fittings and hose lengths. |
Is your block currently in the car, or is it out ?
This is route I have gone when it’s out. Two 2 Qt filters require no bypass even with cold When the oil is warm this is a zero restriction set up. The block is drilled and taped for 1/2” pipe thread.
Block is out. Stripped down, doing machine work now.
I see no reason to buy expensive adapter plate if one could tap the block and thread directly into the block. Great idea. Last edited by PontiacLars; 04-10-2023 at 05:01 PM. |
But since my decision to remote mount was made after the motor was in the car. I used the Canton block plate, it has a provision for the oil pressure sender to screw into it about where the stock housing does, so that is helpful.
73 T/A 455, 4speed |
When I was doing my engine I read a lot about this as I was adamant that I would use a remote mount. I'm sure that it was stated that tapping the block does away with the bypass facility in case the filter gets blocked therefore completely starving the engine of oil in such circumstance. I went for the butler kit but replaced the crappy barbed fittings for proper an fittings and -12 lines. My filter is on the core support next to the radiator so has a good 3ft of line each way!
You really want to know the oil pressure that's going back into the motor out of the filter and the 1/2" pipe holes at the end of a filter mount allow you to do that.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 04-11-2023 at 06:12 AM. |
X2, The Canton block plate has the threaded hole for the factory pressure sender on the return line.
The canton adapter looks like a nice part, especially if the pressure sender fitting is on the return line.
