Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Dale
1969 428 Tremec 5 Speed U.S. Army Retired Retired Helicopter Pilot |
Please- the Infinitys are 2.5” deep and hit the metal with 1” sticking out past the kick panels.
How do you like the sound of yours?
The paperwork is in the attic. I will try to get up there this weekend and see if I can figure out which speakers I bought. dale
https://www.crutchfield.com/S-2JthK5...MaAsG3EALw_wcB Dale
Thanks - very interested in the actual depth
I found the paperwork and I bought them at BestBuy. The model number is 43CSC654 which seems to be the same number as the one you attached above. They must have changed the grill since I bought mine.
This is it at Crutchfield, but I think it has been discontinued, https://www.crutchfield.com/S-r3dEr4...-43CSC654.html This is the new one that cross references at BestBuy, https://www.bestbuy.com/site/kicker-...?skuId=6333353 My paperwork says the top mounting depth is 3/8" and the bottom mounting depth is 1 11/16". If I remember correctly, they fit but they were still up against the insulation. Hope this helps, Dale
Thanks Dale - that does help and I was gonna ask if they touched the body.
I ended up with Infinity Reference shallow depth speakers which are the same ones Custom Autosound sells with their kick panels. I painted the kick panels SEM Saddle as I couldn’t find a good match for the door panels otherwise. I’ll have to get used to the color. The drivers side speaker makes contact with the inner body panel and I put hushmat on both sides.
The parking brake pedal I moved at the dash point about an inch towards center - I had to make a plate for the attach point. Both kick panels are for an AC car.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project Last edited by grivera; 04-09-2023 at 04:43 PM. |
