STOCK 403 '79 T/A - at the track and on the dyno. Guess the results
A good friend of mine. Kevin, has a 27k original mile 403 WS7 (WS6 suspension, but with rear drum brakes) 2.73 posi Trans Am.
The ONLY mod that has been done, is the scoop is cut open. Untuned carb, original exhaust with the original pellet catalytic converter still in place. Timing set at factory specs. 245/60-15 BFG Radial T/As. Back when these cars were new, we did not have chassis dyno's and no track was really convenient, so I always wondered just how good/bad these cars performed when TRULY "stock". Kevin's car is the closest to showroom stock that I've been around in a long time, so I talked him into going to the track and to let me make a few dyno pulls :-) We ran it at the track last Friday, and did the dyno today. I'll post the results later, as I wanted everyone to have a chance to take a guess. Track had a DA of 1200' when we got there, and was around 700 when he made his best pass. Dyno is a DynoJet using their "STD" correction factor. EDIT: I'll ask Kevin to verify, but I believe the race weight was right at 3900. Guess away :-)
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust Last edited by Lee; 03-10-2023 at 06:47 PM. Reason: typo |
Bone stock 15.50@90?
The Following User Says Thank You to grandam1979 For This Useful Post: | ||
15.10. 150 hp.
The Following User Says Thank You to jhein For This Useful Post: | ||
16.2. RWHP- 150
stock 78 W72 4 sp cars did upper 15's, ive seen 15.6-15.9. autos did mid 16's according to some magazines. |
The above guess sounds good to me also.
It’s really too bad that Old’s put such crappy heads on those 403 motor’s because there Bore to Stroke ratio they have is darn good.
I do stuff for reasons. |
The Following 3 Users Say Thank You to 25stevem For This Useful Post: | ||
My cousin had a '78 T/A, base 400. Automatic, 2.56 posi. We took it to a track one summer, around '85. His car was stock, but the cat was removed and it had a basic 2.25" dual exhaust system on it. I don't remember the MPH, but it ran 15.7s.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
That is what I was thinking, low 16's and mid 100's on dyno.
The Following User Says Thank You to jerry455 For This Useful Post: | ||
15.9 at 89. Guessing 155hp.
The Following User Says Thank You to soupman For This Useful Post: | ||
15.90 at 85 mph 1/4 mile.
155 RWHP.
The Following User Says Thank You to b-man For This Useful Post: | ||
I’m on same page as those above- low 16s and 150-170 on chassis dyno.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
The Following User Says Thank You to grivera For This Useful Post: | ||
16.55@83 mph. 145 HP at the wheels.
The Following 2 Users Say Thank You to mgarblik For This Useful Post: | ||
With the 2.73 rear, 17.03
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
Worst nightmare
Back when these cars were new I used to hunt them mercilessly.
I loved it when the girlfriend of the owner was sitting in the passenger seat. Friday and Saturday nights were the best times to find these cars running around with their owners not expecting any real competition from some old Bug. Note the dial-in on the side window. Orange County International Raceway 1978, I was 18 at the time.
I had a 403 79 TA,back in the early 90's,,,,If I remember correctly mine had 2.41 gears? Im assuming they were standard? Id guess 16 sec flat
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
A nice breakdown of which version got what gears here: https://forums.maxperformanceinc.com...bQJxV0s4zmZHfM I've seen 2.73 geared 403's, but never seen one with 3.23's - THAT would be interesting to see at the track.
I bought a '79 T/A 6.6 litre WS-6, 4 speed Trans Am in '83 from the original owner with 22K miles on it for my future wife. Rear axle was 3.23 posi, absolutely all stock, no nothing. Took it to Island Dragway in New Jersey, don't know the elevation, but not much, definitely under 1000'. Best I could get was 16.1 sec at 88 mph. I made 4 changes to it. Opened the shaker scoop, straight piped the cat, lighter distributor advance springs, and richer secondary rods in the Q-Jet. The car felt WAY faster. The engine would pull right to 5000 rpm instead of falling off at 4000. I was hoping for 15.0 or less at about 94/95 mph , but my 18 year old BIL spun the car on a wet day and wrecked it before I had a chance to run it again. The wife replaced it with a Mitsubishi Eclipse.
The Following User Says Thank You to mrmark1957 For This Useful Post: | ||
Back in the day racing a hot Bug on the street was usually a bad idea. They get traction. There was a guy who had a 10 sec Giah at our track.
Had a bus engine in it. Big bore kit, duel carbs. |
15.9 @ 84 MPH
Stan
Stan Weiss/World Wide Enterprises Offering Performance Software Since 1987 http://www.magneticlynx.com/carfor/carfor.htm David Vizard & Stan Weiss' IOP / Flow / Induction Optimization - Cam Selection Software http://www.magneticlynx.com/DV Download FREE 14 Trial IOP / Flow Software http://www.magneticlynx.com/DV/Flow_..._Day_Trial.php Pontiac Pump Gas List http://www.magneticlynx.com/carfor/pont_gas.htm Using PMD Block and Heads List http://www.magneticlynx.com/carfor/pont_pmd.htm Last edited by Stan Weiss; 03-11-2023 at 09:13 AM. |
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
My 78 TA with 2.56 TH350 180 HP motor with the cat and a mild 220/220 Cam Dynamics cam ran 14.90s-barely hitting 3rd!
The Following 2 Users Say Thank You to Skip Fix For This Useful Post: | ||
Lee that was at the old Dickinson Track and in good air
