Ok, I think we may have gone off track from the start. Your title referenced Hydro-boost Conversion sent me in that direction. Seeing that you have already installed larger rotors (I'm assuming) and calipers, and your making 15 inches of vacuum, you should have no problem with current braking system. My understanding is that with Disc brakes you need a 1-1/8" Master cylinder. You also need a Proportional valve that is designed for Disc/Disc brakes. Other issue I can think of maybe your brake line size to the rear brakes is designed for drum brakes. The 7/8" bore master cylinder is not gonna have enough fluid to apply brakes properly with a disc/disc system. The Disc calipers use a large amount of fluid because of there size, hence the larger M/C. bore. The other issue maybe you current Brake booster unit. I read it's a 9" single diagram, which in my opinion is too small. (As was mentioned) The dual 9" or even the 11" booster would be much better. Also the pin between the booster and M/C has to be the correct length for the system to work properly. What vacuum line are you using to feed the Brake booster and do you have the check valve located at the booster.?
My advice to you is to forget about the Hydro-boost system, and find a mechanic that can diagnose your current setup and get it working properly. So going back to post #3 Tininjun I understand what you were referencing now. my apologizes.
I'd also like to add this. We ran my wife's 68 Firebird with stock brakes, front disc, rear drums with close to 600 h/p and around 12" of vacuum. We ran an 11" brake booster with a 1-1/8" master cylinder. The car stopped very well. Never an issue. We went to a hydro-boost unit from Jim at Hyda-tech with the new engine, because of low vacuum.
I also run the same unit from Jim at Hydra-tech on my 76 T/A with stock rotors and calipers. Disc/Drum setup. I use a 1-1/8" M/C. The hydra-boost unit will look up all four wheels. It's incredible the stopping power.
As far as your hose question goes, I never use the supplied hoses in the hydroboost kits. I always have them custom made to the lengths I want and run the hoses behind the fender so they are hidden. In fact the best way I've found rather than trying to have someone crimp fittings and hope you have them clocked correctly, is to use the screw together fittings and assemble them exactly the way I need it. They go together much like AN lines. This is what is usually supplied in most hydroboost kits, CPP being one of them, they just don't supply long enough hoses, and the hose you can get just about anywhere locally. I have 3 choices just in the small town I live in. Even Napa sells it and will make it if you wish. |
Now if you're into road racing and/or run some sort of fancy low profile super wide sticky tires then that's a different story. |
Ford and Mopar both used 1" or less. Mopar was really smart and used the same master for both power and manual: just had a nice deep pocket in the master piston for the 2 push rods. Quote:
The link the OP provided shows a dual 7"; a shameful trade habit of one size fits none. A dual 9" will help but not fix a gross hydraulic mismatch. I would wager his master bore is 1-1/8" too, adding more misery to the mix. |
Just remembered that I should have the 11" OEM replacement booster that was on the car when I bought it for the original disc/drum setup. Looked like it was recently replaced and in good condition.
1970 GTO (Granada Gold) - 400 / TH400 |
Well, Scarbird I know you know alot more about brakes than I do. I tried 1" bore master cylinder, new 11" brake booster on my 76 T/A, even changed the Combination valve and had no luck. Went to the hydra-boost brake setup and never looked back.
Anyway, was trying to help the O/P with his braking system. I'm done.
Hydraboost
I currently run a 1-1/8" with a disc/disc master/proportional valve. 91 Camaro 1LE (D52?) front calipers and 04 Cadillac CTS rear calipers. The car stops exceptionally well.
Moved to this master from a 7/8" due to excessive pedal travel when first getting it going. Never drove the car with that setup as it didn't feel right so can't testify to if the braking was poor or not. Ran the system for 4 years like that with a "tee" for the return lines and it was fine. Just converted to a dedicated return and a new Tuff Stuff 1300psi pump. Cannot confirm what the previous pumps pressure was, but it was lower (from examining the difference between relief valves) and the system still performed quite well. I would be looking at your master and proportional valve setup if you aren't seeing the braking performance desired. Also recall having to watch for some calipers as they withdrew (to prevent drag) and needed a lot more fluid movement to get them back to contact with the rotor.
68 GTO, 412, 3.73, LGT700 5 speed, hydraboost, FiTech |
Chuckie: this is NOT personal, but simply trying to knock down some of the myths promoted that are not true and constantly promoted as fact.
No worries. I very much value your input. All good here. Thank you.
The Following User Says Thank You to chuckies76ta For This Useful Post: | ||
Also, keep the troubleshooting tips coming...
