Cam help identify
I have this cam and lost the card. trying to figure out what this number bring up
My guess would be that it is these Comp Cams lobes.
Stan
Ground with a 110 LSA
Also note the cam was ordered with a "B" suffix code after the lobe numbers. In this case the seat duration (advertised) could be, but not always, altered by one or two degrees less duration. Also the lobe lift might have 0.001" additional lift. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 02-11-2023 at 06:02 PM. |
Looks like you have a stout cam
Cam
Thanks guys... I figured something like that but not sure.... Maybe a good fit for a 535
Stan
