Instead of messing with the intake, use the correct flange gasket.
Pontiac flange gaskets for Pontiac Quadrajets, to the left 1970-74, to the right 1975-79. FWIW |
The Following 2 Users Say Thank You to Kenth For This Useful Post: | ||
![]() Quote:
After that I top it off with a 3/4" thick Nitrous plate which is essentially a spreadbore open space with spray bars. I will end up making my own gaskets. Peter |
Sooooo, i put a divider in a lightly ported Torker I, couplea decades ago. Drove around, checked a month later and found it sucked into Runner #8.
If ya do any such divider install, go thick on the gauge, and trap it on all edges, real good. |
The Following 2 Users Say Thank You to Half-Inch Stud For This Useful Post: | ||
![]() Quote:
My plan its to cut a groove on the 3 faces using my milling, so the divider gets press fitted in place and then tig weld it in place. If it flies away...Ill buy a lottery ticket. Peter |
The Following User Says Thank You to besserspat For This Useful Post: | ||
