Old 01-13-2023, 09:11 PM
Mike S's Avatar
Mike S Mike S is online now
Default What size front tires?
Wondering what everyone is running for front tires on 15" rims. I am putting 275/60 on the back and was thinking 215/70 on the front. Just not sure how it will look with 28" diameter on the back and 26.5 in the front.
Old 01-13-2023, 09:15 PM
AG's Avatar
AG AG is offline
I run 275-60-15 in the rear and 235-60-15 in the front on my '72 A-body.
Old 01-13-2023, 10:23 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
215/70R15 on the front is not too far from the 275/60 rears. 215/70 on a 6 inch wheel, or 225/70 on a 7 inch wheel.
I got a huge deal on some front tires for my TA, years ago. I goofed on the size, got 215/60 tires looks one of those hydraulic jumping contest cars...
Shut it off
Shut it off
Old 01-14-2023, 12:55 AM
Schurkey Schurkey is offline
Kinda depends on what you expect from the vehicle.
Skinny front tires are popular for drag-racing. Hateful for cornering and braking.
What's your priority?
Hint: If someone gets into a collision with me, and their front tires are undersized, they'll have to explain to the Judge how that's safe.
Old 01-14-2023, 02:57 AM
Charlie Brengun's Avatar
Charlie Brengun Charlie Brengun is offline
I have a 275/60r15 and 235/60r15 ombination on my GTO. Drives nice for a street car.
1968 - Pontiac GTO
Old 01-14-2023, 10:17 AM
Stuart's Avatar
Stuart Stuart is offline
You should mention what model/year car you're talking about.
Old 01-14-2023, 12:09 PM
chiphead's Avatar
chiphead chiphead is offline
What's the minimum tread section width on the front that y'all consider safe?
Old 01-14-2023, 12:31 PM
The Champ's Avatar
FWIW - a 215/70/15 is actually almost 27" tall (26.9").
Old 01-14-2023, 12:39 PM
Qball's Avatar
Qball Qball is offline
No rubbing issues either on the front or back with that set up? Stock wheels?
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry!
- Mike
1967 GTO
The Following User Says Thank You to Qball For This Useful Post:
Old 01-14-2023, 12:48 PM
Qball's Avatar
215/65-15 all around
- Mike
1967 GTO
Old 01-14-2023, 02:26 PM
Man. That's a feel good picture!!!
Shut it off
Shut it off
Old 01-14-2023, 07:56 PM
On the cars that I run 275/60-15's on the back, I typically run either a 205/75-15 or a 225/70-15. The 205's are 27.1 inches tall and the 225's are 27.4 inches tall. Just depends on which rim width I'm running on that particular car.
Dad likes to run the M/T 28x6 radial front runners, which has turned out to be an excellent tire for skinny front runner. He runs the same 275/60 tire size on the back that I typically use.
https://youtu.be/XqEydRRRwqE
Old 01-14-2023, 08:20 PM
glhs#116's Avatar
glhs#116 glhs#116 is offline
I drive my Trans Am around corners so I paired my rear 275/60 R15s with 245/60 R15s in front. Looks nice to me. Doesn’t rub with stock wheels.
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 01-14-2023, 08:21 PM
geeteeohguy's Avatar
ID:	605257225 70 14 on the front (26.5") and 235 70 15 on the rear (29") on my '65.
Jeff
Old 01-14-2023, 08:30 PM
I think you have chosen a perfect tire combo front and rear.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 01-14-2023, 09:11 PM
Qball's Avatar
Ha! Thanks! It surely is!! Can’t wait for nice weather in the people’s republic of Illinois to put more miles on the old gal!
- Mike
1967 GTO
Old 01-14-2023, 09:19 PM
locomotivebreath's Avatar
locomotivebreath locomotivebreath is offline
How wide are your rims Qball ?
When I wore a younger man's clothes
Old 01-14-2023, 11:45 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I run 225/70/15`s on front and 275/60 on back. Mostly level. I like to keep the headers off the ground.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 01-15-2023, 02:23 AM
Qball's Avatar
7” I believe.
- Mike
1967 GTO
Old 01-15-2023, 06:07 PM
lust4speed's Avatar
235/60R15 fronts on 7" no-offset rims on my '67 (with 275/60R15 Nitto drag radials on the rear). If I make a right hand turn into a driveway a little too hard while braking the tire will barely rub the dirt off the tread by contacting the inner wheel well center portion. As you can see in the picture, the front is stock height or a little less. Dips, bumps, or anything else without braking and the tires won't rub. I had 205/70R15's and it just seemed under-tired in front.
Mick Batson
