Old 12-27-2022, 11:29 PM
grandville455's Avatar
It’s funny watching grown men argue over something neither own lol!! We would need valid results from prior runs with car and weather compared to the new setup with same conditions etc. so many variables when not done on the same day or even same track if it wasn’t?
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
The Following 2 Users Say Thank You to grandville455 For This Useful Post:
  #162
Old 12-28-2022, 12:44 AM
Stan Weiss's Avatar
It’s on your list Stan…….
Rob,
Thanks. How close is this to your time slip?
60 Foot ET = 1.3445
330 Foot ET = 4.0191
1/8 Mile ET = 6.3541
1/8 Mile MPH = 104.9772
1000 Foot ET = 8.3828
1/4 Mile ET = 10.1123
1/4 Mile MPH = 130.1399
Stan
Pontiac Pump Gas List
  #163
Old 12-28-2022, 01:31 AM
Dragncar Dragncar is offline
My little d port head pump gas 406 was mid 1.3s with under 500 hp.
What does the whole time slip say ? Cars weight too if you could.
  #164
Old 12-28-2022, 01:56 AM
Originally Posted by twinturrbo406 View Post
… I was speaking about some of the unrelated comments but not saying you did the personal stuff no 👍🏻…
… butt theory abound doesn’t change what it ran before , Mike car runs what it runs then and now, it’s real, and factory heads do not make his car faster …
… Mike had zero issues with KRE or the heads, he wanted to go faster so he made the change 👍🏻…
What I am trying to say was something was not right with his KRE headed
combo.
Take a look at this pump gas stroker who won their class in 2016. Notice the cam, a little 261-269 deal.
Made enough HP to get Mikes car down to 6.36 at 107 MPH for 3750 lbs.
His 505 should have been able to make more power than that.
Biggest problem I can see is that cam.
Name:	Screenshot 2022-12-27 at 21-47-40 Pontiac Takes The Win at 2015 Engine Masters Challenge.png
ID:	604140   Click image for larger version
Name:	Screenshot 2022-12-27 at 21-44-50 1_8th Mile ET-MPH-HP Calculator.jpg
  #165
Old 12-28-2022, 02:11 AM
twinturrbo406's Avatar
twinturrbo406 twinturrbo406 is offline
combo.
… well what ever you may believe is wrong with the HP combo, the CV-1’s are now dealing with that also, Mike’s car is footbrake car that’s not light and a head change doesn’t fix a poor cam choice …
… and a wrong cam choice shouldn’t make the car faster, that doesn’t make sense …
… also worth noting is the launch and shift RPM is the same …
… I’m sure Mike is looking forward to figuring out what the new heads will like as far as any tuning changes 👍🏻…
  #166
Old 12-28-2022, 04:21 AM
I had my best 60' ever foot braking. Cheap 10" converter of all things, but I trashed it. Took off at 2200 and flashed it. Most of my hardware was won foot braking. Took me a year to get used to the T brake.
Just help Mike get his 60' foots down. Gotta have it. No self respecting 505 with a 8" converter and 4.10s should have a 1.44.
  #167
Old 12-28-2022, 11:36 AM
Scott Stoneburg's Avatar
Depends on what the converter flashes/stalls to. My 9" converter flashes to about 4500. That's gonna fall short of my peak tq numbers by about 600 rpm. Mike could have the same issue. But it would most likely been the same with the HP heads.
  #168
Old 12-28-2022, 11:59 AM
Stan Weiss's Avatar
You can make all of the engine, and convertor changes you want. But in the end it still comes down to what is the max forward thrust the suspension and tires will let you use. If you are data logging look at G's.
Stan
  #169
Old 12-31-2022, 04:06 PM
Little Jack Little Jack is offline
As the Pontiac world turns, so are the days of our lives.
The Following User Says Thank You to Little Jack For This Useful Post:
  #170
Old 12-31-2022, 05:04 PM
Well, well, look at that. CV-1 talk is good.
Langer posted,now Little Jack posts from a new account.
Its good for the forum.
  #171
Old 12-31-2022, 05:16 PM
Maybe a kid of LiL Jack's ???
  #172
Old 12-31-2022, 05:28 PM
Stan Weiss's Avatar
John,
Or could be after not posting for a while he forgot his password and so needed to create a new account.
Stan
  #173
Old 12-31-2022, 06:45 PM
John,
Stan
It’s me, for some reason I could not log into my account.
Jeff Kinsler’s is the same way.
  #174
Old 12-31-2022, 07:54 PM
Stan Weiss's Avatar
Jack,
Were you able to get out and race any this year? If so how did you do?
It seems ever date on the Warriors schedule this past year I had something else I had to do.
Stan
  #175
Old 12-31-2022, 08:15 PM
If you’re not active here for a while I think you might have difficulty accessing your account, I’m not sure why.
Send a PM to eric_cspan the forums admin and he’ll get you back on using your previous account.
  #176
Jack,
Stan
Yes, we did pretty well going to the finals in one race and lost on a close race.
We ran some mid 4.50s in the eighth.
Broke the converter at one race and had an automatic shifter issue at the last race.
It’s out for a check over at this time. Definitely needs rings but head gaskets looked great.
  #177
Old 12-31-2022, 09:53 PM
Stan Weiss's Avatar
Jack,
Sounds like you had a pretty good year. Are you just going to freshen the engine or do you plan on any upgrades?
Stan
  #178
Old 01-01-2023, 02:40 AM
… launch rpm and shift rpm are the same from what Mike has told me …
  #179
Old 01-01-2023, 05:53 AM
That sentence was totally something he would say. His sense of humor, he made all kinds of posts like that in the past.
Its good to hear from him, been wondering what he was up to.
  #180
Old 01-01-2023, 08:53 AM
Jack,
Stan
We went fuel injection last year. That was expensive enough.
Just new rings and bearings.
