Old 12-26-2022, 09:16 PM
77 TRASHCAN's Avatar
Originally Posted by Formula jg View Post
Thank you for the link.
Unfortunately it seems like there might issues with TSP website, when I click on "Transmissions" the page does not load up, it does for the other selections ie. "Engines" (trying to avoid long distance calling charges).
Just call Cliff. Www.cliffshighperformance.com
Shut it off
Shut it off
Old 12-27-2022, 01:33 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
PTC 10", 0 blade here and it drives like normal, 3% slippage up top and that's on a 461ci making 585hp/565tq. Traction issues even with MT SS 295/60/15 so going to a looser stator converter would be spin city for sure.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
