Fuel Pressure ?
My in dash fuel pressure gauge is not working. How can I tell if the gauge or the firewall isolator is bad ? Fuel pressure is good at the regulator.
OGR
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
Remove the gauge and apply air pressure to it.
I do stuff for reasons. |
By the same method you can test the output of the sender with a meter while the engine is running. If you decide to apply air pressure make sure you don't over pressurize it. Line pressure from an air compressor could ruin it. |
