Old 12-04-2022, 02:04 PM
dlloyd's Avatar
dlloyd dlloyd is offline
Default 1931 Pontiac 401 4 door sedan
I recently bought an original 1931 Pontiac 401 4 door sedan. It is in excellent condition and runs very well except the carb leaks fuel real bad.
I believe it is a Marvel 10-228 / 10-955 carb.
I need to get it rebuilt. Does anyone on here know where I can buy parts and or buy rebuild kit for it. Or does anyone know someone that restores them or rebuilds them?
Old 12-04-2022, 04:28 PM
Stuart's Avatar
Stuart Stuart is offline
Try board member Carbking, he runs a carburetor shop in Missouri. I believe he stopped doing rebuilds but he sells rebuild kits. https://www.thecarburetorshop.com
Old 12-04-2022, 05:01 PM
dlloyd, we need pics of the car.
Agree with Stuart, probably best guy out there.
Old 12-04-2022, 05:03 PM
dlloyd's Avatar
Thanks guys.
I will upload a picture if I can figure it out
Old 12-04-2022, 05:08 PM
dlloyd's Avatar
Default Here it is
I hope this works
The Following 3 Users Say Thank You to dlloyd For This Useful Post:
Old 12-04-2022, 08:23 PM
Worked like a charm.
Car looks beautiful!
Old 12-05-2022, 01:48 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Old Pontiac looks great!
I've worked on the Marvel carb of my '17 Buick quite a lot. Although it's functionally much different from modern carbs, finding and fixing fuel leaks from it is straight forward. Only a couple of gaskets and a seal on the adjustable main jet are the main culprits. Are you sure it's a "leak"- as opposed to fuel overflowing the float chamber due to float and/or needle faults? New floats are availale, not sure about needles and seats.
Old 12-05-2022, 06:54 PM
stevep's Avatar
stevep stevep is offline
Larry Isgro on Long Island did a marvel carb for my 23 Buick years ago. https://www.yelp.com/biz/larry-isgro...retors-wantagh
Old 12-06-2022, 11:14 PM
dlloyd's Avatar
Thanks Jack, where can I buy the floats?
I not sure but it could be the float. I will look closer at it this weekend.
Old 12-06-2022, 11:17 PM
dlloyd's Avatar
Thanks Steve, I will try and get in touch with Larry.
