Old 11-02-2022, 09:18 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
Default Performer RPM center divider mod. ???
i'm cutting down part of the center divider, to clear the throttle blade of a holley 3 bbl. so far, it's been marked off and a notch has been roughed in. since the top of the notch will now see some air/fuel flow, i'm wonder how to finish it off. i would think, it should be at least rounded. maybe a little knife edged would be good (don't want it too thin and risk it flaking). maybe it doesn't matter and leaving it square is ok. is there a preferred shape when doing this mod?
“We don’t build a ‘luxury’ car. We build a performance car then we make it luxurious.”
Old 11-02-2022, 09:24 PM
shaker455's Avatar
Matt,
Oddly enough I posted an RPM mod I did years ago.
Yes you can bring your edges to a point or knife edge to do what you need.
When I 1st got my 3-bbl its was lean on sec side so I suggest to use an O2 sensor wideband for tuning
Jeff
Servicing the Pontiac community over 20 years
Old 11-03-2022, 10:03 AM
78w72 78w72 is offline
here is how SD does the notch, rounded off knife edge.
pic is playing with cutting open a 4 hole gasket.
Old 11-04-2022, 07:25 AM
i'll go ahead and copy the sd style of notch and thanks for the extra info on the carb. that will help in the long run.
Old 11-04-2022, 09:02 AM
Juliano Juliano is offline
I used a thicker carb gasket and cut out the middle divider between the secondaries
Old 11-30-2022, 10:43 PM
this is the finished version of my center divider. it ended up being a little more involved than i originally planned. i intended the notch to be just enough to clear the throttle plate. when i put the carb on and opened the secondary up, you could see plenty of the flat carb flange/center divider. you could even see some of the divider through the primaries. it probably would have been just fine that way, but i couldn't leave well enough alone. the center divider was narrowed between the primaries. the notch for the secondary was lengthened (didn't make it any deeper) and blended as best i could. for better or worse, at least it lets the secondary open.
https://www.youtube.com/watch?v=bc_c23dqAKk
ID:	602801   Click image for larger version
ID:	602802   Click image for larger version
ID:	602803   Click image for larger version
Old 11-30-2022, 11:23 PM
turbo69bird's Avatar
Most aerodynamic shape is a rain drop so that should help. Although Wilson intakes used to rough the bottom and lower sides of intake runners to keep air /fuel in suspension w turbulence. Am which is probably why they waffled the bottom of that intake like that. So sometimes aerodynamics isn’t what you want Best is testing look at those 4 hole spacers they used w the long angles openings under the carbs forget what they were called . Some carb shim style locates had something similar for reversion./ pulses under w jets https://www.motortrend.com/how-to/pi...t-performance/
960 HP @ 11 psi, 9.70 at 146.
Old 12-01-2022, 09:36 AM
Fun fact; the real shape of a raindrop is not a smooth stretched spheroid. Rather is a 3-D ink blot.
Otherwise, the cartoon raindrop is a rather good aero shape.
