Old 11-03-2022, 07:38 PM
242177P's Avatar
242177P 242177P is offline
Originally Posted by jerry455 View Post
... 1LE rotor. ... It was the same wagon rotor only with the 4 3/4" bolt circle instead of the wagons 5" bolt circle.
A minor, and not so minor, detail has been overlooked. B-body rotor was 1.25" thick, like the pickup trucks. 1LE rotor was 1.10", which meant you could re-use your F-body calipers. HTH.
  #42
Old 11-03-2022, 08:05 PM
The aluminum 9-1/2 drums were on many GM makes. It might be difficult to find 2 good used ones. I've not known any aftermarket brake manufacturers to make them in aluminum. I'd run them on my TA, if I could find 2 usable specimens...
I currently run D153 pads on my stock calipers. These pads were used on 3/4 pickups in the 80's. 3/4 tons had light and heavy duty brakes. The D153 pads are the light duty pads.
I run a pair on the Chevelle. There was a company at one time reproducing them. I'll have to dig into that and see if I can find the info.
https://youtu.be/XqEydRRRwqE
  #43
Old 11-03-2022, 08:32 PM
Formulas Formulas is offline
national parts depot for aluminum drums
Item # C-5809-3CA
Brand: Cardone
  #44
242177P's Avatar
IIRC, it was Dennis Kirban. HTH.
The Following User Says Thank You to 242177P For This Useful Post:
  #45
Originally Posted by Skip Fix View Post
...I've been lucky with the 81 TA setup on my 78 never had much issues over 30 years with it. Adjustable prop valve and I think the silicone fluid keeps the ratchet working better.
Best thing for the 79-81 WS6 calipers and the Eldo units is EVERYTIME you shut off the car, engage the parking brake.
  #46
Old 11-03-2022, 09:22 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
The last B-body rotor that was 1.25" thick was the '76 and earlier. The '77-'96 B-body rotors were 1.10", both for the 11.5" and HD 12" dia. My '89 9C1 Caprice had the 12" x 1.1 rotors with a 5x5.0 bolt circle and 1/2" studs.
The cool thing about the 1LE rotor is it's the HD 12" B-body rotor, but with a 4.75" bolt circle, so a hybrid.
The Following User Says Thank You to hgerhardt For This Useful Post:
  #47
Old 11-04-2022, 12:55 AM
64speed's Avatar
64speed 64speed is offline
I have the Wilwood D52 calipers on the front that accept stock size pads. On the back I have a Ford 9 inch and have the mid 90s Ford Explorer discs. With hydroboost the car stops GREAT. It has the parking brake in hat style rotors. Parking brake cables are gonna be a pain in the ass though because the wilwood kit that Quick Performance sells for conversion is universal.
  #48
Old 11-04-2022, 09:15 AM
Formula8's Avatar
Formula8 Formula8 is offline
As others have said, I would start with what your intended use is and from there, determine why your current set up is coming up short. If it is just a stock(ish) appearing driver and you are just looking for improved stopping power, you are unlikely to find it in rear discs. I would probably invest in things like the master cylinder, brake booster, adjustable prop valve and dialing in the pad selection.
That said, I have a different theme going with my car and wanted the brakes to match that so I ended up with C4ZR1 13" fronts and 12" LS1 rears. That was quite the improvement but probably at least half of that came from a dual diaphragm booster, C3 master and Wilwood prop valve. Most of the rest of the improvement was from way aggressive GMPP pads that had an incredible initial "bite" but produced an equally incredible cloud of brake dust all down the side of my car and wheels. I swapped them out for a set of Powerstop Z26's and that eliminated the dust but also eliminated the nice tight initial bite. I would have a tough time recommending that pad.
What I am getting at is I would do some diagnosis on what you have and get that in proper order and balance and then decide if you need to make some changes. I am not sure if I agree with the "locking a tire" oversimplification as for most, a lot of it has to do with the "feel" of the pedal and many of these 60-70's era brakes are going to struggle to lock up a modern "pro-touring" type/sized radial tire much less feel like modern car.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
  #49
Old 11-04-2022, 09:18 AM
Skip Fix Skip Fix is online now
'96 Police Caprice and Impala SS 614 pads will also fir D52 calipers if you feel the need for a larger pad.
Speedway also has a 1LE rotor with 7/16 studs vs the metric studs.
  #50
Old 11-04-2022, 09:45 AM
Tarl Tarl is offline
Another cool thing about the The cool thing about the 1LE rotor is it fits under a standard Rally II wheel. Loved these on my 66 Lemans, wish I could put them on my 68 Firebird.
1966 Lemans convertible 455/5spd
1968 Firebird convertible 400/4spd
Need more Pontiacs!
  #51
Old 11-04-2022, 10:57 AM
Here ya go in case you missed it. These are exactly what I run on the Chevelle, and to my surprise they currently have them in stock. Formulas actually found these listed.
https://www.npdlink.com/product/drum...than-mo/206310
  #52
Old 11-04-2022, 11:21 AM
One thing i have noticed as they age rear drums do not work as well as the first day you put them on and are adjusted perfectly even with perfect hardware / adjuster, they just seem to lose effectiveness as time goes on
thats just something that is eliminated by disc
I have bumped up against brake limits a few times in my life not a bad area to upgrade unless you drive like gramps 100%
  #53
Old 11-04-2022, 01:32 PM
Driving some curvy CA roads my 78 TA's stock disc drum had some serious fade!
  #54
Old 11-04-2022, 01:47 PM
JLMounce JLMounce is offline
Yes, this is one of the areas where having that rear disc really starts to make sense. If you need repeatability, discs are the way to go.
The stock type 11" front and rear disc with aluminum calipers instead of the stock iron stuff will provide really great fade resistance for your standard street performance stuff on typical rubber. With upgraded pad compounds that work with higher heat, that same brake system becomes pretty capable in non-competitive auto-x as well.
Once you start putting the car on R compound tires in auto-x situations or especially on big open tracks. That's when having the big 14" rotors starts to become not only beneficial, but in some instances necessary.
-Jason
1969 Pontiac Firebird
  #55
Old 11-04-2022, 04:13 PM
Mount Umunhum Radar Station Road off Hicks Road looking over Santa Cruz CA!
  #56
Old 11-04-2022, 05:39 PM
ZeGermanHam's Avatar
I just installed the Wilwood universal parking brake kit a week ago. It was super easy and only took me about an hour to install. Works well.
1998 BMW 328is (track rat)
  #57
Old 11-05-2022, 10:08 AM
leeklm's Avatar
leeklm leeklm is offline
Did not read every response here so this may have been mentioned... if you do choose rear disc, do not haphazardly piece it together. Be sure to use the right combination of verified parts such as master cylinder, prop valve, brake line sizing, calipers, e-brake, etc. The wrong combination of parts can leave you wishing you left your drums on. Ask me how I know....
Sent from my SM-G965U using Tapatalk
