Old 10-21-2022, 08:11 PM
czar97's Avatar
czar97 czar97 is offline
Default Hood hinge beyond bending back?
Wondering if there’s any saving this hood hinge. Hood still has great alignment lol. Not sure how, but it does. Just pull it and bend it back?
ID:	600912   Click image for larger version
1972 LeMans' $41 Nose Job - Father Son Project Car
350 4bbl
3.55 Richmond Gears w/ Auburn Posi
Old 10-21-2022, 09:53 PM
GtoFM's Avatar
GtoFM GtoFM is offline
You can try to straighten it but most likely will happen again. The rivets are probably binding and holes are out of round. Try these guys https://www.hoodhingerepair.com/about/
Old 10-22-2022, 08:09 PM
tjs72lemans tjs72lemans is offline
I'm guessing you're done with that one. Once it starts, there's no going back. They only sell them in pairs new, but there are guys with parts here that may sell one.
Old 10-22-2022, 10:28 PM
Trevor78 Trevor78 is offline
It bent for a reason, that's only a part result of the damage.
Old 10-22-2022, 11:41 PM
wbnapier wbnapier is offline
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 10-23-2022, 09:18 PM
czar97's Avatar
I believe it bent due to me not lubricating the pivot points enough. I always rock the hood back and forth (and push backwards toward the windshield) to try and get them started when closing the hood. Is that not the way to start closing it?
350 4bbl
Old 10-24-2022, 12:56 AM
dataway's Avatar
dataway dataway is offline
Rocking helps get sticky hinges to close ... but the rocking also loosens up the rivets, wears the joint out. Good oiled hinge should just push back and down pretty easily.
