Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Garage clearance
1) Holley metering blocks taken off Holley 8896 Dominator - $40
2) Holley HP fuel bowls with floats. Brand new. - $150 3) Isky valve spring locators - 1.52” O.D. / 0.732” I.D. / 0.630” hole - $25 4) ISKY Chrome Moly dual valve spring retainers. Dyno use only. ISKY part # 275-ST / Inner step dia. – 0.730” / Outer step dia. – 1.120” - $50 5) XRP 45 deg. Hose ends #8 x 4 - $40 6) Comp Cams beehive valve spring ID locators # 4705-16. Designed for #26915 & #26918 Beehive™ Springs. Locator O.D. – 1.300” / Locator I.D. – 0.638” (modified from 0.575”). Spring I.D. – 0.875” / Locator thickness – 0.060” - $25 7) ProComp mechanical oil temperature gauge #5441 - 2 5/8” - $50 8) ProComp Ultralight electrical oil pressure gauge #4327 - 2 1/16” - $50 9) ProComp Ultralight electrical transmission temperature gauge #4357 – 2 1/16” - $50 10) MSD tach adaptor 8920, new in box - $75 11) Lakewood driveshaft loop - $50 12) Trend pushrods x 16 / 5/16” x 0.080 wall / 9.500” - $100 13) Comp Magnum pushrods #7658 x 16 / 5/16” x 0.080 wall / 9.650” - $100 14) Manton pushrods x 18 / 3/8” x .145” wall / 9.400” used for 12 dyno pulls - $150 15) KRE pushrod guideplates 3/8” - $50 16) Stamped steel pushrod guideplates 3/8” - $30 17) Fuel line for Holley carb with inline filter 6AN size - $25 18) Cometic MLS 4.380” 0.060” head gaskets used for 12 dyno pulls - $150 Shipping not included. Will be shipping from Massachusetts Thanksgiving weekend to avoid higher shipping costs from Canada.
www.hobracing.com |
more pictures
www.hobracing.com |
More pictures
www.hobracing.com |
Pictures 4
www.hobracing.com |
Last pictures
www.hobracing.com |
Still available
www.hobracing.com |
Everthing is still available
www.hobracing.com |
1) Holley metering blocks taken off Holley 8896 Dominator - $20
2) Holley HP fuel bowls with floats. Brand new. - $150 - SOLD 3) Isky valve spring locators - 1.52” O.D. / 0.732” I.D. / 0.630” hole - $25 4) ISKY Chrome Moly dual valve spring retainers. Dyno use only. ISKY part # 275-ST / Inner step dia. – 0.730” / Outer step dia. – 1.120” - $50 5) XRP 45 deg. Hose ends #8 x 4 - $40 6) Comp Cams beehive valve spring ID locators # 4705-16. Designed for #26915 & #26918 Beehive™ Springs. Locator O.D. – 1.300” / Locator I.D. – 0.638” (modified from 0.575”). Spring I.D. – 0.875” / Locator thickness – 0.060” - $25 7) ProComp mechanical oil temperature gauge #5441 - 2 5/8” - $50 8) ProComp Ultralight electrical oil pressure gauge #4327 - 2 1/16” - $50 - SOLD 9) ProComp Ultralight electrical transmission temperature gauge #4357 – 2 1/16” - $50 10) MSD tach adaptor 8920, new in box - $75 11) Lakewood driveshaft loop - $50 - SOLD 12) Trend pushrods x 16 / 5/16” x 0.080 wall / 9.500” - $100 13) Comp Magnum pushrods #7658 x 16 / 5/16” x 0.080 wall / 9.650” - $100 14) Manton pushrods x 18 / 3/8” x .145” wall / 9.400” used for 12 dyno pulls - $150 15) KRE pushrod guideplates 3/8” - $50 16) Stamped steel pushrod guideplates 3/8” - $30 17) Fuel line for Holley carb with inline filter 6AN size - $25 18) Cometic MLS 4.380” 0.060” head gaskets used for 12 dyno pulls - $150
www.hobracing.com |
