Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 10-23-2022, 08:22 PM
jm455ho's Avatar
jm455ho jm455ho is offline
Default Garage clearance
1) Holley metering blocks taken off Holley 8896 Dominator - $40
2) Holley HP fuel bowls with floats. Brand new. - $150
3) Isky valve spring locators - 1.52” O.D. / 0.732” I.D. / 0.630” hole - $25
4) ISKY Chrome Moly dual valve spring retainers. Dyno use only. ISKY part # 275-ST / Inner step dia. – 0.730” / Outer step dia. – 1.120” - $50
5) XRP 45 deg. Hose ends #8 x 4 - $40
6) Comp Cams beehive valve spring ID locators # 4705-16. Designed for #26915 & #26918 Beehive™ Springs. Locator O.D. – 1.300” / Locator I.D. – 0.638” (modified from 0.575”). Spring I.D. – 0.875” / Locator thickness – 0.060” - $25
7) ProComp mechanical oil temperature gauge #5441 - 2 5/8” - $50
8) ProComp Ultralight electrical oil pressure gauge #4327 - 2 1/16” - $50
9) ProComp Ultralight electrical transmission temperature gauge #4357 – 2 1/16” - $50
10) MSD tach adaptor 8920, new in box - $75
11) Lakewood driveshaft loop - $50
12) Trend pushrods x 16 / 5/16” x 0.080 wall / 9.500” - $100
13) Comp Magnum pushrods #7658 x 16 / 5/16” x 0.080 wall / 9.650” - $100
14) Manton pushrods x 18 / 3/8” x .145” wall / 9.400” used for 12 dyno pulls - $150
15) KRE pushrod guideplates 3/8” - $50
16) Stamped steel pushrod guideplates 3/8” - $30
17) Fuel line for Holley carb with inline filter 6AN size - $25
18) Cometic MLS 4.380” 0.060” head gaskets used for 12 dyno pulls - $150
Shipping not included. Will be shipping from Massachusetts Thanksgiving weekend to avoid higher shipping costs from Canada.
Name:	driveshaft loop 2.JPG
ID:	600990   Click image for larger version
ID:	600991   Click image for larger version
ID:	600992   Click image for larger version
ID:	600993   Click image for larger version
www.hobracing.com
Old 10-23-2022, 08:23 PM
jm455ho's Avatar
more pictures
ID:	600995   Click image for larger version
ID:	600996   Click image for larger version
ID:	600997   Click image for larger version
ID:	600998   Click image for larger version
www.hobracing.com
Old 10-23-2022, 08:24 PM
jm455ho's Avatar
More pictures
ID:	601000   Click image for larger version
ID:	601001   Click image for larger version
ID:	601002   Click image for larger version
ID:	601003   Click image for larger version
www.hobracing.com
Old 10-23-2022, 08:25 PM
jm455ho's Avatar
Pictures 4
ID:	601005   Click image for larger version
ID:	601006   Click image for larger version
ID:	601007   Click image for larger version
ID:	601008   Click image for larger version
www.hobracing.com
Old 10-23-2022, 08:26 PM
jm455ho's Avatar
Last pictures
ID:	601010   Click image for larger version
www.hobracing.com
Old 11-01-2022, 11:29 AM
jm455ho's Avatar
Still available
www.hobracing.com
Old 03-24-2023, 05:47 PM
jm455ho's Avatar
Everthing is still available
www.hobracing.com
Old 06-19-2023, 05:52 PM
jm455ho's Avatar
1) Holley metering blocks taken off Holley 8896 Dominator - $20
2) Holley HP fuel bowls with floats. Brand new. - $150 - SOLD
8) ProComp Ultralight electrical oil pressure gauge #4327 - 2 1/16” - $50 - SOLD
11) Lakewood driveshaft loop - $50 - SOLD
www.hobracing.com
