Old 10-18-2022, 06:22 PM
gtorich gtorich is offline
Default KRE 290-295 heads by SD
Trying to get hold of dave for some info, assume hes busy, any that has these heads, im looking to get new viton seals..............cant seem to find the size on these.
Thease heads are from 2010 with about 25 thou miles on them.............having the motor redone with my oil issues..........dont know if the seals are bad or not, just thought i would get them just in case...............another thought if getting new seals, does it pay to get springs and guides also.
Rich
Old 10-18-2022, 06:48 PM
You can check the seat pressure on springs and see if they have lost much vs replacing them automatically. And check how the guides feel if excessive wear. If down that far I would replace the seals.
Old 10-18-2022, 06:56 PM
25stevem's Avatar
25stevem 25stevem is offline
There’s two questions that need to have a answer, and I can resolve one for you,
You need seals for 11/32” valve stems, but the 2nd part that I can’t answer is if the guides are are sized for seals that are .530” ID, or if they have been cut drown to .500”
If the heads have solid guides then you will need the .500” seals.
Comp cams sells both.
Any time you disassemble the heads and the in doing so the valves get pulled out through the seals, then new seals should be installed!
It’s cheap insurance.
Also good oil control calls for good seals and good valves.
If your machinist finds any valve stems that are worn more then .001” then they should get replaced, and replace with valves with hard chromed stems like the factory builds with.
And the same with .001” or more worn valve guides.
I do stuff for reasons.
The Following 2 Users Say Thank You to 25stevem For This Useful Post:
Old 10-18-2022, 08:02 PM
Oh boy, was hoping this was gonna be easy. lol..........the only thing i find for the guides are 2.400 long full bronze valve guides............hoping Dave can fill me in on the other stuff, so far havent heard from him.............was hoping someone with this set up could fill me in with some info............at least that way i could get the stuff to the builder.
Out of curiosity , should all this stuff be going out of whack with so little miles, 20 some thousand.
Rich
The Following User Says Thank You to gtorich For This Useful Post:
Old 10-18-2022, 08:07 PM
Precision sized guides
High flowing multi angle valve job on our Rottler SG8 seat and guide machine
Ferrea stainless steel valves with multi angle cuts for better off the seat flow
Chrome moly retainers with 10 degree locks
Viton seals on intake and exhaust guides, for the best oil control available
This i got off SD website..........not much help there...........hopefully i can get hold of Dave soon..........unless someone has this info handy, i can find any of my stuff.
Rich
Old 10-18-2022, 08:15 PM
Put down the beer and found this.........Maybe25 steve can figure this out.
Name:	SD scan today.jpg
Old 10-19-2022, 06:59 AM
25stevem's Avatar
Rich, just call KRE and ask them
They will know right off the top of there head, no pun intended.
The Following User Says Thank You to 25stevem For This Useful Post:
Old 10-19-2022, 08:26 AM
Will, do.............i thought Dave did something different with the heads other than the cnc stuff.
Rich
Old 10-19-2022, 08:55 AM
chuckies76ta's Avatar
They don't make the 99893 springs anymore. As far as valve seals, can't you remove one and measure it. There are lots of sources for valve seals. A replace spring for the Crane 99893 is a Howard 98445.
68 Firebird. IA2 block, 505 cu in, SD Performance E-head, Solid roller 3600 weight. Reid TH400 4:11 gear. 29" slick.
Best so far 9.95@134 mph. 1.43 60 ft.
Old 10-19-2022, 09:10 AM
Thanks for that info on the springs.............the motor and heads are at a shop, i was trying to get stuff ahead of time.........
Called KRE, they said the vinton seals are 11/32........530
Rich
Old 10-19-2022, 09:12 AM
Just was reading this on Crane website.. on seals. https://www.cranecams.com.au/index.p...ew-viton-seals
Old 10-19-2022, 09:16 AM
The PSI spring CT1225ML maybe another spring for replacement. There are a few slight differences. Would need professional head guy to confirm.
Old 10-19-2022, 09:34 AM
Hey Chuckies...........thanks for the info, so far it looks like those crane seals are all on back order.
Rich
Old 10-19-2022, 09:38 AM
These guys have lots of seal too. https://www.cvproducts.com/
Old 10-19-2022, 09:02 PM
54nomore's Avatar
54nomore 54nomore is offline
The comp cams # for those seals is 529-16
Old 10-19-2022, 09:14 PM
Hey thanks guys, i finally got it figured out............didnt take all day.......yeah, it did.
Rich
Old 10-20-2022, 01:12 PM
ta man ta man is online now
I have a good set of 99893's if needed.
Old 10-20-2022, 01:51 PM
Hey ta, if in no rush, could you hang onto those, i havent heard anything from the shop yet..........who knows when he is gonna start checking things out.
Rich
Old 10-20-2022, 06:29 PM
Yes will do.
