Old 09-08-2022, 07:59 PM
nas t eh nas t eh is offline
Originally Posted by bdk1976 View Post
I'd assume it's a cracked 350 and pay him like its a boat anchor unless HE can confirm otherwise.
This,
< $50 dollars
73 T/A 455, 4speed
Old 09-08-2022, 08:14 PM
433lemans's Avatar
433lemans 433lemans is offline
Probably a YH code if it’s a 428.
I have one stashed under my work bench for a spare, probably should sell it.
Is your 428 drilled for 4 bolt mains, but with 2 bolt caps? All of mine have been. This should narrow it down considerably for him if he can at least feel the extra bolt holes on the main saddles if not see them.
Old 09-08-2022, 09:28 PM
Slick Poncho Slick Poncho is offline
I have a 69 YH code 428 2 bolt main block that is NOT drilled for 4 bolt mains. I have saw many times were people are under the impression they were all drilled for 4 bolt mains, I confirm that is not the case!
Old 09-08-2022, 09:38 PM
433lemans's Avatar
No impression meant. I've had 3 of them, all drilled. I meant this to be something for the OP to look for to help him, not intended to be gospel.
Old 09-08-2022, 09:40 PM
East East is offline
Transfer lug cast for large journal block
Old 09-08-2022, 10:23 PM
389 block, no transfer lug. Same for the 400.
421 block transfer lug.
The 428 has it as well as 326, 350 and 455 blocks. That ought to muddy the waters a bit.
326 showing the transfer lug.
Old 09-08-2022, 10:49 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Wanna trade? I really wish this 2-bolt 69 YH 428 wasn't drilled for 4-bolts, it would be my future race engine and get splayed caps.
Name:	YH 428-1.jpg
ID:	598135   Click image for larger version
Name:	YH 428-2.jpg
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 09-13-2022, 03:29 PM
geeteeohguy's Avatar
It’s probably as already mentioned above a ‘69 428. The standard Bonneville 360 hp 428 had the low performance #46 small valve heads with press in studs, the block had 2-bolt main caps and 3 core plugs (freeze plugs) per side.
A 421 would have 4-bolt mains and 2-core plugs per side.
Agree with this. I had one, and it had the 46 heads and the two bolt caps. Was drilled for 4 bolt caps, but not equipped with them. A great engine for a build, IMO.
Jeff
Old 09-14-2022, 06:03 PM
Pecosbill's Avatar
I’ve got a set of those 46 heads from a 69 if you need them. Came off a 428. Previous owner included them in the sale of his car is the reason I have them. He had built the 428 by putting stamped 64 H.O. heads on it, forged pistons, etc. and that car could fly!
Pecosbill
Old 09-14-2022, 07:43 PM
433lemans's Avatar
So, for the OP, how did you turn out on this block?
Old 09-16-2022, 10:01 AM
DK03 DK03 is offline
I'm picking up the block, heads, intake, long branch headers and a 4 speed trans today. I'll let you know exactly what it is once I get it back to my garage.
The Following User Says Thank You to DK03 For This Useful Post:
