Tried the Lunati 271/278 cam. Went faster.
I'm sure some of you have seen my posts on making changes on my car and going nowhere. Well I had a front timing cover leak and while I had it apart I figured I'd put the Lunati 271/278 @ .050 solid roller in. Installed it at 106 ICL. 108 LSA. Also put some 1.72 rockers on which gives me close to .700 lift. I doubt putting the 1.72's on the Jones cam would have made much difference. Went to Muncie Friday night for a test n tune but only got one pass. Was supposed to be from 6 to 10 but they quit it around 8 because of a gamblers race. That sucked. Anyway it ran faster but spun a little on the line. Pulled really hard on the top end. Need to get the 60 ft down. One image is from old timeslip with Jones cam and other with Lunati cam. Car just feels lighter with the Lunati cam.
Nearly 3 mph is a nice gain
The Following User Says Thank You to PAUL K For This Useful Post: | ||
Time for 60-foot tuning.
I have one ran in several combos, ported iron heads and eheads. Always performed well. In a conversation with Butler many years ago he called it the “old stand by cam” .
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
Would have figured Jim to say " Boy, that's a big cam." |
The Keens ran a 276/282 @ .050 / .740 lift camshaft with their Supercharger engine in 1998 in a 347 cid engine and loved it.
Best MPH at the time with the car. So the only difference, in the different engines, was they ran their engine a higher rpm and with boost vs NA and a much larger engine for JC's engine. Cam is just letting the engine breathe properly. If designed correctly. Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
What were the specs on the jones cam?
Jones cam card
Don't know why it keeps flipping the photo. |
Nice increase from a cam swap. Did you change the valve springs at the same time? I have very good luck with an old Lunatic grind as well.
Scott,
Using same valve springs. Ken, This is a new converter. 4800 stall from Perfect Converter Co. |
Did you change converter and cam at the same time?
Scott,
No. Same converter. Only thing I changed was the cam and rockers. Kept everything else the same. Didnt even touch the carb. |
The Following User Says Thank You to BLANK1 For This Useful Post: | ||
That car should 60 foot in in the 1.4's and with that MPH it should run around 10.5's
