My car is a 62 GP with tri-power. I'm planning to put phenolic spacers under the carbs for heat isolation. Will that also require different tubes from the manifold to the choke?
What thickness spacers should I use, and who sells them? Thanks, Les |
I might have a set I no longer need.Tom
I do,center is for a 61-65 intake and has a fitting for a PCV.Tom
Like these.Tom
https://www.ebay.com/itm/37405929968...MAAOSwKoNic8lH |
Pontiac TriPower website listings for choke tubes 61-63 imply that different choke tubes may be needed for applications with the PCV spacers than for applications without PCV spacers.
As I remember when I added the PCV spacers on a 61 manifold I used the choke tubes I had with no problem. However, those tubes were probably from a 64 which is a slightly higher rise manifold and may have need the longer choke tubes. |
I notice that spacers appear to be available in 1/2" and 1/4". Any advantage to either?
thanks, Les |
Go to Pontiactripower.com , or call John Wright @ 847 767 2868. He has what you need.
I have quite a few spacers, gaskets, and the choke tubes to work with raised carbs. I do have a few OEM spacers from the early sixties' cars.
PM me with your needs.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
Check out Hotrodcarbs.com.
Thanks everyone for your help.
Les |
