How to test fuel gauge
1971 GTO with fuel gauge not working. Is there a proper way to test the gauge on the bench?
1971 GTO Convertible 455 #64 Heads, HO intake and carb with MSD HEI, RAIII exhaust manifolds and 3:55 posi |
I hooked mine up to a volt/ohm meter and measured the resistance as I swung it through it's arch. Someone will chime in with the spec for it, mine was something like 10-90 ohms I think.
On the reverse of the fuel gauge there are a total of 3 threaded "posts." To bench test you will need some jumper wires + a 12 volt car battery and some fixed 3 watt or higher resistors. On one of the posts you will see a 6-32 nut and a washer which connects that post only to the metal backer. That post to the backer panel is your ground. One of the other posts then gets 12 volt + battery power and the last post goes to a variable resistor (the sender inside of your gas-tank) which ends in ground. And that is how the gauge tells you your fuel level.
On the wire that is the variable to ground (the sender) 1 or zero ohms= E. 44 or 45 ohms = 1/2 scale. And 89, 90, or 91 ohms = Full. I will go and take a photo of my test here so you can see how it's done.
Peter Serio Owner, Precision Pontiac |
The Following User Says Thank You to Peter Serio For This Useful Post: | ||
Fuel gauge test
In the #1 photo, test wires are: pink wire with the black tracer= 12 volts battery + power. Black wire = ground and the brown wire = variable resistance (the gas-tank sender).
These are 1970 rally gauges; but standard gauges, your 3 test wires would plug onto the posts the same way.
Thanks I will take a look this weekend. This has been helpful.
Jeez, sorry, I read gauge, and thought sender.
