Old 06-17-2022, 08:29 PM
tomslik190's Avatar
tomslik190 tomslik190 is offline
Exclamation + battery cable routing?
For 70-72 +battery cable routing on RA and HO cars, i understand the cable runs from the starter, through cable retainers mounted to the motor mounts, that route the cable UNDER the motor mount and then up to the battery. Is this correct? it looks like only one of the cable retainers is available from Ames, which i have, but i don't know if it mounts to the FRONT motor mount bolt or the REAR motor mount bolt. Some applications have either 2 cable retainers or 3, but the drawings are not very clear. If you have this setup, can you post some photos of it? I have a 68 GTO, but I can't run the cable through the tube that was used 67-69 due to interference between the tube and the cast RA exhaust manifolds so i need an alternate solution, and the 70-72 way seems to be a good choice I don't want to burn the cable and start a fire! Thanks in advance for any advice and solutions. TOM
Old 06-18-2022, 12:06 AM
OG68 OG68 is online now
This is the setup for my 68. Ames cable tube, motor mounts. RA Manifolds.
ID:	592952   Click image for larger version
ID:	592953   Click image for larger version
2007 Cadillac SRX
Old 06-18-2022, 10:08 AM
Originally, on '71 & 72 455 HO & I believe '70 RA builds, there was a stamped steel clip that bolted down off the front & rear motor mount mtg bolts. I've also ran across instances where the rear mtg hole on the long style mount was the only one that used that clip, & a loop style clip bolted further forward off of an oil pan bolt. The latter method may have been a dealership service procedure(?) both routing methods kept the starter wires away from the large exhaust manifold.
On the sideways tube deal, believe Pontiac originally routed the positive starter cable on '68 & 69 HO & RA engines through a sideways version of the tube. This original method basically helped cook the positive starter cable. last year, Winston (69HurstJudge) posted his concern with that style of routing & I believe instead uses the later clip method on his '69.
Old 06-18-2022, 02:55 PM
tomslik190's Avatar
OG68- that;s the setup i tried, but with the tube mounted to the motor mount, i cant bolt the manifold to the head due to the manifold hitting the tube - there just isn't room for everything. A friend of mine brought over his 69 RAIII judge for comparison and has your setup with plenty of clearance. Just my luck i guess, and differences with aftermarket parts. my car has a 455 with 6x heads, so its nothing unusual.
The Following User Says Thank You to tomslik190 For This Useful Post:
Old 06-18-2022, 03:23 PM
tomslik190's Avatar
i must have the "short" motor mount? I bought Ames N180F that has a comment in the catalog that says "This clip mounts to the front engine mount bolt. The short front clip is currently unavailable.". Is this the only clip i need or is there another one that mounts to the rear motor mount bolt? the pic on the package seems to show this clip mounts to the rear motor mount bolt, along with the starter reinforcement
Old 06-18-2022, 03:24 PM
tomslik190's Avatar
there is also this drawing...also not very clear
Old 06-19-2022, 10:18 AM
kk68's Avatar
kk68 kk68 is offline
Here are the two original clips on a 71 RA Judge.
ID:	592995   Click image for larger version
ID:	592996   Click image for larger version
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
The Following User Says Thank You to kk68 For This Useful Post:
Old 06-19-2022, 07:41 PM
tomslik190's Avatar
That's what i was looking for. The smaller retainer on the right isnt reproduced. I wonder what the odds are of finding a used one? Or i suppose I could just bend up one of my own. Thanks!
Old 06-21-2022, 04:09 PM
Another tidbit related to this, on 69 RA cars the positive battery cable has a retainer clip on the front of the inner fender, I guess to keep the cable away from the power steering pulley. Same in 70-72? Btw in 69 RA cars without power steering did not use that extra clip. All 69 tubs have the dimple on the tub.
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
Old 06-21-2022, 05:44 PM
That dimple is on my 68 as well.
2007 Cadillac SRX
Old 06-21-2022, 07:08 PM
exactly what was mentioning in prev response,
there is more than one factory clip that resembles the short clip.
