I ordered a set of 3" tailpipes from Mbs Performance in Maryland. I ordered them on a Thursday and they shipped them out the next day. I got them the following Tuesday. Very fast service for the times we live in. Even more important was the fit which was dead on. All I had to do was shorten the ends to fit my muffler placement and where I wanted the tips just under the bumper edge. The mandrel bends were perfect. Thought I would pass this info along because I had heard stories that fitting 3" tailpipes in a 2nd gen was a pita. These went on my 79 but I assume the fit would be the same for the other years.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
The Following User Says Thank You to prostreet64 For This Useful Post: | ||
Is it possible to post a photo or two?
I bent mine 26 yrs ago and it is a PITA. the rear rubber brake line will prolly need to be relocated (down, out and rearward on the rear ttube) and a little massaging of the fuel tank CORNERS helps also. You say under the bumper???? a 79 has turn downs behind the wheel. 76 was the last of the straight outs IIRC. Good to know they can be purchased!!
I the FlowMaster 3" setup on my '71 and the rear stabilizer links were the biggest PITA.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
I will try to post some pics later today or in the morning. I was not trying to match the factory routing at the back. These pipes are made to exit the rear under the bumper. Main thing was that the bends are perfect for getting up over the axle and over to the side where they go between the leaf spring and the inner fender. I do not have a rear sway bar so not sure if that would be as issue. The drivers side brake line junction on the axle tube is close but it does clear.
These guy are right up the street from me I buy all my bends from them to make my headers they have always been very friendly and helpful.
do they offer complete kits?
i've used torquetech which was AWESOME, but they retired i have their 3.5" into X and 3" out i've used a few of their kits and all were perfect |
Like mentioned, I've always used Torque Tech in the past for the 3" stuff and it always fit perfectly, but as we all know they are long gone and another source for something like this just hasn't been out there.
Would be nice to see some pics and know that we have another vendor out there that has stepped up to the plate for us guys that like to run 3" or bigger tail pipes, and have them actually fit properly. Even more so if they actually mimic the shape and design of the OEM tips like Torque Tech did. |
I bought and extra Torque Tech set- I think the last he had before retiring and going Rving!
[IMG]
While mine are NOT perfectly in place due to no motor installed YET...they are fully attached to the car. The usual hangars just after muffler and the slide in hangar by the "end". Currently the front of the exhaust is "wired" up to ABOUT the correct height. Also note I did this back in maybe 93 or 94 (when dinosaurs roamed the land). Exit is out/back/down behind rear wheel...where the TA tips WOULD be...but just couldn't get a tight enough bend to make tips work...so she is slightly naked..lol Last edited by 67Fbird; 05-24-2022 at 07:18 AM. |
Hope these are helpful. First pic got in there somehow? Anyway will attach 2 more in next post.
2 more.
yeah the sway bar location makes it difficult to get that "zig" up top for the straight shot by the leaf..
will these mbs of maryland tail pipes work with a center muffler exit ?
That might be a problem with there 'stock' setup, but if they new you had center outlets maybe they could bend a set to match. They make them up per order anyway.
Lyells stainless exhaust in Ontario Canada makes full 3 inch exhaust..my car has the first set of 3 inch tailpipes on it from them. I just had to chop an inch of the upward section before the rearend for a good fit. I believe all their tailpipes now have the same modification.
