Quick cam suggestions ?
I've run in a fresh 462 and ran into a oil pan leak , valley pan leak and a light coating of milky substance on the inside of the valve covers.
Needles to say I removed the engine and am in the proces of taking it apart again. I've always been wary about the XE274H cam in the build ( negative posts ). The problems I'll address but , I've been searching thrue a lot of posts about a fitting cam and I only get more confused about the load of info to absorb. My goal was 500 hp So now that it's on the engine stand and I need to order parts anyway , any quick suggestions on the cam ? 462 , BRC pistons , eagle rods , eagle cast crank. KRE D-ports cleaned up and 2.11/1.66 valves , Harland Sharp 1.5 RR Q-jet modified according to Cliffs instructions , RPM intake. Everything port matched , Hedman 1 3/4 headers. TH400 / TCI converter stall 2000 , 3.31 : 1 gears. |
DO you have any flow numbers on the heads?
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
If they where just cleaned up they likely flow some 272 intake cfm at between .550” and .600”.
They should make you a easy 500 hp if your compression is atleast 9.5 and if your new can pick will provide you with .550” lift, which should be your target number to hit. Those HR rockers check in at 1.6 in ratio.
I do stuff for reasons. |
The Following User Says Thank You to 25stevem For This Useful Post: | ||
Check out the specs of the SD Performance "stump puller" cam. Something similar to that should work well in your build. I have used that cam with great results in a 461 iron head and a 455 KRE head motor. One car had 3.31 gears and the other had 3.08 and 3.42 gears. Cam worked well in all of them.
Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
The Following User Says Thank You to leeklm For This Useful Post: | ||
Bob, I have something similar, but with a T2/Demon, 3200 converter. I ordered the top end stuff from SD Perf. I told Dave I wanted around 500 hp and to get down the track in around 11.5 in a 3200 lb car. He set me up with KRE 295 @ .550" dports and a .570 lift Stump Puller.
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
The Following User Says Thank You to tooski For This Useful Post: | ||
The heads should flow 270 cfm. cleaned up.
Compression calculated to 10.33:1. I'm going to check out SD . Thanks , Bob. |
I checked out SD for the 'old faithfull ' cam and I'm no 'scrooge' but the price difference between the XE274H $ 170.00 and old faithfull $ 470.00 is something that boggles my mind ?
The SD performance one is a hydraulic roller, the XE274H looks like a hydraulic flat tappet at that price? HR cams are just more expensive.
1968 - Pontiac GTO |
The Following 3 Users Say Thank You to Charlie Brengun For This Useful Post: | ||
Oil leak related.. Invest in a ONE PIECE oil pan seal.
be gentle with the edges, but It can solve many leaking issues.
Hard to go wrong with the RAIV cam (Melling SPC3) for a street 455.
I would avoid the XE-cams like the plauge. Noisy ping prone POS on anything but 7.5:1 CSB. JMHO |
I think you meant to say spc-8 for RAIV Spc-3 = rounded nose 744 Sent from my iPhone using Tapatalk
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
I'd like to hear more about this too as I have them in my engine. I always thought under pressure they would flex and be closer to the 1.5
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
anyone else heard of this or can confirm it? |
SD Performace website list the HS 1.5 rocker ratio as "actual ratio is typically around 1.55." also mentions the 1.65 ratio closer to 1.7-1.72 as well
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt |
I went through this a couple yrs ago with the HS rockers. I checked the lift of HS 1.65 using light checking springs with a dial indicator and got a ratio of 1.78. However after installing the running springs the actual ratio dropped to 1.69.
I did the same test with my HS 1.5 s and got a running ratio of 1.56 The aluminum rockers flex a bit when fully loaded. BTW: Test was done using CC valve springs with 350# at .560 lift Larry |
You are absolutely correct, SPC-8 it should be.
Exhaust ti intake ratio flow?
Bullet has the Ultradyne lobes I've had good luck with .
Been around since the 50's or 60's. Not sure whar exactly you're looking, so I'll provide links to a few pages. Straight up solid lift and hydro roller cams are apparently custom grinds these days. http://schneidercams.com/hydraulicli...shafts-23.aspx http://schneidercams.com/solidroller...shafts-13.aspx
Thread Tools | |
Display Modes | |
