Went a new best today
535 pump gas with some 112 for a safer tune. 3710# with driver
1969 LeMans..Liberty Blue 2001 WS6..Sunset Orange 1973 Pro Street Firebird..Lucerne Blue |
Very nice congratulations
Very nice! Great 60" time for the ET too.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
That's getting it done! Good job!
Nice MPH as well! Congratulations!
Nice times. Congrads
Very nice for that weight!
Keep in mind though that running any octane level above what you need to keep detonation at bay will cut into the HP numbers.
I do stuff for reasons. |
Congrats Jeff!!!!! Always a great day at the track when you get a new best
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
That's awesome.
Is the car caged? |
Very nice!! Glad to hear of the new best. Care to share the specs of the combo?
Congrats! How come 112 is pump gas?? I ran straight 91 on my 11.1 pump gas 505
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
I never said 112 was pump gas. Motor is 11.1. and will run on pump gas which I run on the street. I choose to run some 112 at the track for a safer tune considering the junk gas at the pump.
I have done the same so far. Mine is just over 11 to 1 . I think it's safe on pump gas but mix a gallon or so of 110 in to be sure. At least until I am sure of the tune.
That was a misprint on my phone sorry, supposed to be if not is! I get being safe but if the tune is on at that comp u wouldn’t have to worry,
No problem... thanks
That is a nice time slip. 60 foot, mph for the weight. Can we get more info on the top end, cam ?
High ports cnc by SD, northwind intake, 1100 pro systems carb. Custom comp cams solid roller. Turbo 400 with TB 9" ati converter. 31x14 tire with 456 gear
The Following User Says Thank You to 455 pontiac For This Useful Post: | ||
To Quote Jerry Reed form Smokey and the Bandit!!!
Boogity, Boogity, Boogity!!!
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
Great 60' time. My car is 11.2 CR and I run 93 pump without issues. I've had the motor apart and no signs of detonation.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
