Pro Comp EFI manifold
After the recent discussion about Speed tech, I browsed these and decided to order one. Price was DEFINITELY right for a new Pontiac efi intake. It looks good, no obvious defects. I don't need it for anything currently, so it'll get put away for the future. Just wanted to pass along for those in the market for a Pontiac efi intake.
Looks like the new version of the Tomahawk.
Yes, I think so. The names have all been muddled by now. It's patterned after the Holley street dominator of old
It's a little weird to me that they used a spread bore / square bore carb flange on a manifold that will likely never see a spread bore patterned throttle body.
Considering it's a port injection manifold and distribution would be handled by the injectors, I'm not sure if it matters. They probably took their standard single plane design and just added injector bungs. Nothing wrong with that. I'm liking what Luhn is doing with the old Offy 360's. Adding injector bungs with a bottom plate setup to accept a holley mid or high ram.
Yes, that is cool. I usually can't afford their stuff unfortunately
As far as distribution in the SD style manifolds, seems they've done fine with 1" or more spacer for years now. ETA: I can tune cylinder to cylinder fuel trims, so if there did happen to be an issue it isn't insurmountable. Though I think it's likely to only be the normal inner vs outer runner discrepancy.
'65 Tempest 467 3650# 11.30@120.31 Last edited by Scott65; 03-25-2022 at 02:20 PM. Reason: Addition |
I bought one from them but the injector rails they had listed wouldn’t fit the spacing of the manifold. I just sent it all back.
The manifold I got looked kinda crude in a couple areas but I wouldn’t of hesitated to use it. I just decided to let it go for now. On the plus side, I had no problem with the return process. Murf |
One day maybe I'll pull the Edelbrock rails off my current intake and see if they fit. If not then I guess it will be a custom job
Doesn't the universal edelbrock EFI stuff come with drill to suit rails? As long as you know you're going to have to deal with that, buying parts setup for customization seems like a good route to follow.
I have no experience with the undrilled Edelbrock stuff. Mine were finished, and fit my SuperVictor efi intake perfectly. My thinking is the port centerlines oughta be the same so maybe my rails will work with both intakes. A question without an answer at this point.
The Tomahawk I have need weld at the top of the ports if over 2.300. The original Holley Street Dominator does not. They changes something in the cast mold to add the injector bung pad-not drilled on original Tomahawks..
I have the Speedmaster single plane carb manifold. I got it with heads a few years ago. I assumed the injection manifold would be the same just with the pads drilled for injectors.
I was surprised that they didn’t seem to be the same. The ports on the injection manifold were smaller & not as well shaped. I thought it was kinda odd but I don’t know nothing. Sent from my iPhone using Tapatalk Pro |
I haven't studied it that hard yet. Don't foresee needing it anytime soon. I bought it mainly in case the Pontiac port injection manifolds dry up, and because the price was very good. Hopefully it'll be usable if/when I need to.
'65 Tempest 467 3650# 11.30@120.31 Last edited by Scott65; 03-25-2022 at 05:58 PM. Reason: Correction |
The Edelbrock rails fit fine on the Tomahawk/SpeedMaster/ProComp/etc. manifold.
They are all a copy of an SD Performance-ported Holley Street Dominator that had injector bungs added to it. I own several versions of it- they all seem to match up the same. Side Note: Luhn Performance made me some fuel rails for my Offy 2x4 conversion- the port spacing is the same as the E-brock's too. His rails come in various finishes, but I like the anodized black ones I got-- and his prices were better than Amazon's price on the E-brock rails.
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
I ran that PC / HSD / Tomahawk copy manifold for a few years Scott. It's actually quite good and sits nice and low. I honestly would have preferred a square bore flange on the EFI variant because there are zero options for spreadbore throttle bodies etc. Nothing the square bore sealing plate that comes with it can't fix but just personal opinion.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
FWIW on the flow bench a square bore is much more even than a Qjet. Qjet the primaries are too close to the front runner entrance and need a spacer to help it make the turn more evenly. Square bore they are more centrally located.
Currently I plan to run this Northwind 4150 converted for EFI... Still a long ways away... SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" |
Not a lot out there, but they have a pic on their facebook profile.
https://www.facebook.com/Luhn-Perfor...0580403276627/
EFI fuel rails
these guys have a lot of materials to make fuel rails. It was pretty easy when I made mine for a '56 Desoto Hemi.
https://www.ebay.com/itm/20287212557...MaAh0lEALw_wcB |
