#81
One around the squirrel cage hole......and another.......to the left......on top side of blower fan housing..
#82
Close. On this car squirrel cage hole and other is at the bottom where it angles in. I do think you’re right though Non A/C cars are like that. This is an A/C car.
#83
The housing and not the firewall?
#84
Blocks
Ok I'm new but not stupid. If I was greedy and had a list of cars with missing engines and there vins. It would be easy to mill the front of engine down 100th of inch to erase stamp and restamp. I'm not an idiot. You guys act like you worked there at the plant. Unbelievable I think we not suppose to talk about this but I will. Original is original. Maybe we need to calibrated our dimensions on block. If ys and yz same block same casting numbers some dumb guy mills the front pays the professional restamper gets 4 bolt main put Vin on it and there you go. Ha
#85
The Following User Says Thank You to FASTASSBIRD For This Useful Post: | ||
#86
Block
I never said it was a restamp.
#87
#88
Under the blower housing....on firewall..on non-AC.....
AC cars have a 2nd one under evap housing... |
The Following User Says Thank You to Green Hornet For This Useful Post: | ||
#89
and the milling used made broach marks across the whole front. Very tough to do, or find someone with equipment and time to do it. Doing 4 bolt mains, would require USED caps. All the replacement ones are billet machined steel.. Then, you would have to get the block "ALIGN bored" Which would require a LOT off attention to details regarding the front and rear oil seals as the crank gets moved up away from the seal surfaces. All that could cost a good 4K in labor alone and Still, you have the cam holder closer, the timing cover closer to the chain.... Pontiac made 4 different 400's with the Same block in 1970..... Hell with the numbers if you need an engine go with what ya got, if you dont have the original.
#90
Blocks
I just went out to the garage, and found the second one on my car - I had no idea that two were there!
The Following User Says Thank You to unruhjonny For This Useful Post: | ||
#92
what is or were is the squirrel cage hole
#93
The big blower motor squirrel cage fan from the blower fan goes through this hole. stamping areas are anywhere around these two holes on a AC car.
#94
And there is a 9 at the begining ? ( Norwood car?_)
#95
thank you again for your reply
The Following User Says Thank You to grd777 For This Useful Post: | ||
#96
mine is a June car;
Where the "9" or "0" would be it has a small letter "o" top justified, infront of the rest of the characters; It looks a little funny.
#97
Just stumbled onto this thread. Can we have an update here? Was the block ever able to reunite with its’ original chassis?!?!
#98
Yes we’re also like to hear if the Block is going to be reunited with its original car
