Old 02-06-2022, 09:30 PM
Petegto Petegto is offline
Default 67 Catalina posi-traction
Can someone tell me if a 67 Chevy Impala rear end with posi rear end work in my Catalina?
Old 02-07-2022, 10:52 AM
Not even close, big Pontiac used unique setup that is hard as heck to find today
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
Old 02-07-2022, 12:56 PM
PONTIAC LARRY's Avatar
PONTIAC LARRY PONTIAC LARRY is offline
Your 67 Catalina assuming US built not Canadian. Has gear interchange 1965-1970 Pont B body cars 12 bolt 8.875 ring under a 10 bolt cover 31 spline bolt in axles. Using the 71-76 Yoke (pinion flange) also the some 71-76 Pont B stuff to as I understand ... Hard to find a gear lower than 2.93 in a Safe-T-Track , look for a parts car stick 3 spd-4 speed car or 2+2 for a 3.23 or 3.42 is tough to find, FABCraft Metalworks can help with possibly some new 3.55's not sure if any inventory though.
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.3 1/8th pump gas n/a
66 Star Chief Executive 57k mile
69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4
69 Firebird 400 Burgandy/Black
70 Olds Rallye 350 F85 4 speed 3.91's
70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455
74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8
2020 RAM 1500 SLT 4x4 5.7 A8 Hemi
2007 Hummer H3 3.7 liter turd
2019 Chevy Spark petrol car 38 mpg
The Following User Says Thank You to PONTIAC LARRY For This Useful Post:
Old 02-07-2022, 02:14 PM
Thanks guys appreciate the help. If you know of anyone who has one please pass along my email address or posting.
Thanks again
I was going to call Bulter performance maybe they can help.
Old 02-07-2022, 03:14 PM
they turn up from time to time (usually the highway geared series) on the parts section of this forum and Franks but usually sell very quickly
1969 Bonnie Cvt
Old 02-07-2022, 03:29 PM
I had a 67 2+2 3.42 Safe T Track but sold it to a friend , will keep eye out
Old 02-07-2022, 04:29 PM
Yes tried Franks they don’t have any.
Old 02-09-2022, 02:33 AM
scld1354's Avatar
scld1354 scld1354 is offline
Hopefully this is allowed.... facebook user John M. Kuchtiak has two posi rear ends from a Buick Wildcat (should be a bolt-in to 65-70 big Pontiac)
Sent from my SM-A505U using Tapatalk
Originally Posted by lust4speed View Post
Welcome to the broken nipple club - I'm a charter member.
Old 02-09-2022, 07:38 AM
Thank you for the lead I’ll try to contact John.
Greatly appreciated.
Peter
Old 02-09-2022, 10:09 AM
Hi again if I bought the 66 posi rear from the Buick Wildcat do I need to change the lower control arms and don’t know if the Buick has bolt in or c clip axles?
He also has a complete pumpkin with the 3:42 gears if I can just use that from a Buick B body.
Old 02-09-2022, 03:14 PM
RE: Buick rear , IDK what kind of gear size or size specs on gears or axles on those but I found a better picture and it looks dainty and has a weird square cover
Old 02-09-2022, 03:26 PM
Not the gear ya want but here is a proper 67 Pont 2.73 Safe T Track and one could use a spacer or thick ring set of Fabcraft 3.55s if they are available $500 Nebraska
https://omaha.craigslist.org/pts/d/k...427130898.html
Old 02-09-2022, 03:40 PM
Fabcraft shows their 3.55 (65-76 Pont B car) out of stock and the page for the spacer for Series 1 diffs (2.73 is Series II) shows that their 3.55 set does not require a spacer to be used on a Series 2 Posi 2.73-2.93-3.08
NOTE THAT FABCRAFT’S 3.55 GEAR SET FOR THE 8.875″ REAR END WILL WORK ON YOUR SERIES II CARRIER WITHOUT THIS SPACER ( the required longer ring gear bolts are not included — contact us for proper bolts )
FABCRAFT’S 3.55 GEAR SET WILL NOT WORK WITH A SERIES III CARRIER (3.23 THRU 4.33 )
QUESTIONS ? — of course there are questions !!
CALL FABCRAFT 1-800-208-8242
65 ‘- ’76 PONTIAC FULL SIZE 3.55 RING & PINION
$475.00
FABCRAFT 1965-1976 Pontiac /G.M. Full Size 3.55 Ring & Pinion Gear Set
'65 '- '76 PONTIAC FULL SIZE 3.55 RING & PINION
Description
WE ARE CURRENTLY OUT OF STOCK ON THIS GEAR SET — BUT WE ARE HOPING TO MAKE ANOTHER RUN OF THEM — WITH ENOUGH INTEREST FROM OUR CUSTOMERS !!
PLEASE CALL TO GET YOUR NAME ON OUR ” LIST “
ITEM: RA5-0241
Old 02-09-2022, 05:46 PM
Default 67 Posi
Thanks Larry
I called Fab but nothing available as you mentioned. They are taking names on a list to see if they can get a bigger customer base in order to make it worth it for them to invest.
I’m going to call that other contact you sent me and see what’s up with that unit. Really don’t want 2:73 but it’s a start.
Thank you for your time.
The Following User Says Thank You to Petegto For This Useful Post:
Old 02-10-2022, 04:19 PM
Pete, I replied on Facebook to one of your posts to a link of a rear for 2 hours from Utica in Penn Yan NY , its a big 76 Buick Estate Wagon Posi for $450 and never mind its a wag leaf spring suspension it shows the familiar Pontiac cover like the 65-70 Pont B cars. The 8.875 lived on 71-76 in B cars beyond just Pont and still had 31 spl axles thru 76. Good chance its a Towing option car since its Posi and the tow perf axle option that year is a 3.23 vs a STD 2.93 , those guts should swap over to your 67 housing and it might be a 3.23 ! so I would be all over it !
Old 02-10-2022, 04:32 PM
Default 67 posi Catalina
Larry thank you I’ll try to find that on Facebook that would be a great find. The Craigslist ad you sent me yesterday I called the guy and sent him a email but he didn’t reply. I also received another reply from someone on this forum that he had one too but he never replied. Both rear ends had 2:73’s Posi’s for my car.
Really appreciate all your help and I keep trying to get this done.
I owe you a few beers!! Lol
Thanks again
Pete
Old 02-10-2022, 08:22 PM
rustyrelic rustyrelic is offline
http://forum.jdrace.com/viewtopic.php?t=526
check out this link, and then contact JD. Basically there is little nothing for the 65-70 Pontiac big-car rear, and stuff from other years or car lines will not work.
The Following User Says Thank You to rustyrelic For This Useful Post:
Old 02-11-2022, 10:42 AM
What he linked above... 1965-1970 Pontiac (FULL SIZE CAR REAR) That is your main difference. The rings are the same 8.875 diameter But that is where the similarities STOP.
Ring gear bolts Pontiac are 7/16" x20 (Right and left hand thread early or late)
Ring gear bolt s Chevy are 3/8 x 24 (right hand thread only)
Pinion shaft on the Pontiac is 1.875
Pinion shaft on Chevy is 1.625
----- -- THIS is the main reason your not going to fit the Chevy gear in a Pontiac housing.
Pinion spline Pontiac is 28
pinion spline in the Chevy is 30
Pontiac rear is bolt in axle 31 spline and the Chevy is 30 spline c-clip axle
In 1971 -1976 The Pontiac rear was used in all the mid HP engine from 400- 350 cube motor with 4 bbl motors Gears will interchange from the 2 eras BUT you MUST use the yokes from each era with the era gears. 1971 -1976 era pinion spline is 30 not 28 like the 65-70 era. The gears will interchange
Axles will again NOT interchange because of the axle bearing differences and also the spline pitch was different too.
1977 -1985 there was a final form of this Pontiac rear and they really down sized it ...remember the cars in this era were way under powered so really the 10 bolt 8.5 would do the job just fine . pinion shaft decrease from 1.875 to 1.625 (basically the same 8.5 pinion was used in the 8.75 10 bot cover with 12 bolt ring design . It was used in the Caddy DeVille and wagons and maybe special tow package ordered cars of the era. Again NO PARTS in the aftermarket for this 8.75 rear.
Hope this help cover the Pontiac FULL SIZE car rear for you. and why you can not interchange the gear sets. Pinion shaft size is too small to transplant into the Pontiac housing - There could also be a different pinion to ring engagement height also But we never really went that far to check... Just not a BIG following for high performance ratios for the rear these days...Most cars have been demo derbied in the past. GM made steep gears for these rears and you can from time to time find a 3.73 3.90 4.33 gear set at a meet some one is selling that they have no idea what it fits we found (2) 4.33 gears that way 7-10 years ago. Sellers though they were truck gears...lol.
Good luck on the hunt.
Jim Mitschke
J D Race
Old 02-11-2022, 11:45 AM
Thanks Larry I found a guy that has a bonneville same year as mine. For some reason these guys want to sell stuff but they don’t call back. Go figure.. I’m frustrated
Old 02-11-2022, 12:04 PM
Old Men probably
Thor: "Why don't you just send me an electronic mail?"
Strange: "Do you have a computer?"
Thor: "No, Why?"
