#41
Great build here and hopefully some track results eventually
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
#42
Happy accident to report in the spirit of accuracy, Geoff kindly pointed out to me that my carb is actually off of a 1965 421 based off of my tag number 3898S. The guy who had sold it to me told me it was off of a 1965 GTO, and i never checked it out - i ASSumed he was right. When i ordered the carb kit, i just gave Jon the numbers. My mistake for not verifying that, but i had intended to find a 421 carb to run anyway due to my camshaft and head work, figuring that would be a good match for the improved flow. Guess i can check that one off of the list.
"I know just enough to keep me here, but not enough to get me out" |
The Following User Says Thank You to Cardo For This Useful Post: | ||
#43
That is some nice numbers and a good looking motor!!
#44
Cardo,
thanks for the details on the build. Great numbers, Im trying to figure out where the SCR vs DCR numbers fall on these "stock/mild" builds Can you share: 1. what was your piston to deck clearance? 2. Did you deck the block? 3. Which head gasket # was used? Thanks Frank T |
#45
Piston to deck is .003 down in the hole. Block was decked - had a very slight twist to the deck. Head gasket is the Butler SPM 19375 gaskets. Butler says they crush to approx .045. Hope this helps.
#46
Thanks for posting the results of your build...it is close to what I am looking to do in my '64. Except I'll be running a Tri-Power, '64 GTO heads and plan on a 4" stroke. I would be very happy to end up with 1 hp/cid. Based on your engine I'm now much closer to an actual recipe.
#47
Nice numbers. My 67 Firebird has a 65 389 as well. Here is my dyno run. As far as I know all original but it may have a different cam. Not sure.
67 Firebird Convertible |
#48
How does that cam idle? Is it close to a 068? Have fun with that hot 389, I'd like to do that someday.. Enjoy and thanks for posting.
Sounds like a nice setup Cardo. A really sweet cruiser...but I think your cam specs out to 219/227 @ .050 lift (you gave the total duration and listed it "@ 050" ", I was like "WHA?!?! =D )
Anyway, congrats on doing a great build. -b Ponchy
I don't know about the idle vs 068, i don't know that i've heard a 068 specifically to say. The idle is slightly lopey, but nothing crazy for sure. Tom Vaught's commment pointed out to me my error in the duration number, i did post the correct numbers somewhere after that. Thanks again all for the encouragement. Really looking forward to getting this out on the street, but it'll be a while to have the time to get it all together. Hoping for mid to late summer for a first drive. I still have to build the body too. http://forums.maxperformanceinc.com/...d.php?t=806153
#51
You will be so happy you went conservative when your in the middle of city traffic with the family in the car.. I used to hate taking my family out with my car loping and loading up. What a pain in the a$$! I will never use the 041 cam again except to hold the back door open lol....
#52
![]() Quote:
I'm a "If-you-want-it-done-right-do-it-yourself" kinda guy, so when I saw that, I just looked up the cam and published the correction. Ponchy
No problem. I appreciate it. It needs to be right if anyone that wants to duplicate the build.
#54
Every 068 I've ever heard idles dead smooth.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
#55
Still learning about Pontiac engines. The 76 heads you used, are those stock for that engine or off another year?
Thanks. |
#56
They're stock. The engine came out of a 65 Catalina. It was the 325 hp version. They're almost identical to the 77 heads that would have been on a GTO... in fact i don't really know or think that there was any difference. I am getting ready to build a duplicate of this motor, but since Dave at SD Performance isn't doing cast iron heads any more, I will have Kauffman do this next set.
#57
ONE WAY OR THE OTHER, HE HAS A REALLY NICE STREET ENGINE FOR CRUISING.
Happy New Year! Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
#58
Sweet!
Let's make welfare as hard to get as Veterans benefits! |
#59
Happy New Year Tom! Hope you're staying warm this winter! I got to put about 200 miles on this engine so far, and it's great as a street engine. Absolutely no problems with drivability, no pinging, plenty of low end power. Idles great, and runs on pump gas. Had some fun with it in the driveway after I got it put together. https://www.youtube.com/watch?v=lTMnf3KjvzI
#60
That makes more sense than the 262/268 first mentioned!
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
