It's low overlap. From the card I read it was 11* degree's of overlap. GT |
Camshaft Machine Company, I am fairly sure still grinds the Wolverine Camshaft profiles.
I might still have a 744 High Lift Wolverine Cam on the shelf. Are you interested? Tom V.
The Butler cam has 56 degrees overlap and the UD cam has 54 degrees.
Use Advertised Duration Numbers http://www.wallaceracing.com/overlap-calc.php When duration is increased and LSA is constant, the valve overlap is increased. When overlap is increased, vacuum is lower, cylinder pressure is reduced. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 12-05-2021 at 07:47 PM. |
