Old 11-10-2021, 10:42 PM
grivera's Avatar
grivera grivera is online now
Originally Posted by Jay S View Post
If I read it correct Murf understands what it will take to make the plate work, except I don’t think it requires any machining to drop the plate at the center stand adjusters, the lifter hitting is what is holding up the plate, not the center hold downs. All it would take to make the plate work is to grind or file on the plate at the lifter or lifters that is to tight on maybe one or two lifters, then adjust the plate down accordingly. A couple lifters are not letting the plate drop enough. I mentioned it a few posts earlier, Randy’s videos have said the exact same thing.
If your not willing to grind on the plate, bale on these 2148s and get a link bars set up. Personally I would get these: https://butlerperformance.com/i-2445...tegory:1234800
I too mentioned the grinding early on (post 92) - according to Randy it’s required to fine tune. Not saying that will definitely solve the issue but it should be tried.
http://forums.maxperformanceinc.com/...7&postcount=92
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
The Following User Says Thank You to grivera For This Useful Post:
  #162
Old 11-11-2021, 07:50 PM
P@blo's Avatar
P@blo P@blo is offline
Originally Posted by 68hotbird View Post
my test mule motor with the sealed power lifter and dogbones and the ford spider have now been seriously abused for a few thousand miles and it is working awesome. I will be doing a couple more soon.
Hey Hotbird can you share the details of your set-up?
  #163
Old 11-12-2021, 11:46 AM
Here's the thread from awhile back:
https://forums.maxperformanceinc.com...highlight=ford
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
The Following User Says Thank You to Singleton For This Useful Post:
  #164
Old 11-12-2021, 06:47 PM
1980 TA 1980 TA is offline
I appreciate all those that have taken the time to help me try to sort through this.
I have decided I'll be ordering the Johnson lifters that Jay S linked in his post. It's time for me to move on from the plate and or dog bones and get things back on track. I like tinkering and understand its part of the hobby but I have spent 8 plus hours trying to fit the plate and or dog bones over the last couple of weeks, mostly on weekends or evenings and am not finding it enjoyable anymore. I spent probably 2 hours a couple of days ago starting over from square one on the plate after reading everyone's suggestions. I removed all of the push rods and tried to adjust the plate one last time and can't get it close enough to convince me with some more time spent grinding that its going to work and have ample margin for error.
I want to get the motor assembled so I can get the parts out of my shop and try to get caught up on work projects.
Thanks again to all those that tried to help.
The Following User Says Thank You to 1980 TA For This Useful Post:
  #165
Old 11-23-2021, 12:52 PM
grivera's Avatar
Originally Posted by Murf View Post
Will, so far so good. Don’t have many miles yet , tho.
1980TA, is there any chance of the dog ones trying to cock sideways as they are being held on one edge instead of the center? Just wondering. Please keep us up to date.
Murf
Have you put any more miles on it? Any issues or is all well?
Will Rivera
  #166
Old 11-23-2021, 01:37 PM
Murf Murf is offline
Sorry Will, I probably won’t have any news for quite a while. I’m trying to sort out pushrod length, polylocs & valve covers. I’m messing with putting A/C on it over the winter,
Right now I’m pounding out floor tile getting ready to install LVT. Hopefully the last of my house projects for the winter.
I will post up if I get a chance to put any miles on it.
Happy Thanksgiving!
Murf
  #167
Old 11-23-2021, 04:55 PM
grivera's Avatar
Thanks- I’m installing a viintage air sure fit system on mine over the winter- hoping to start in next couple weeks.
Will Rivera
  #168
Old 11-23-2021, 05:05 PM
Cool, I’ll hit ya up if I run into any stumbling blocks. 😁
I think I’m gonna use an underdash unit with the sure fit components under the hood. I’ve heard the underdash unit has a larger evaporator but I haven’t checked with V/A on that though.
I bought their compressor bracket and that’s when I decided I need to try and get more valve cover clearance.
Good luck with yours & keep us in the loop, please.
Murf
  #169
Old 11-23-2021, 08:16 PM
grivera's Avatar
Will do!
Will Rivera
  #170
Old 11-26-2021, 05:49 PM
68hotbird 68hotbird is offline
Default conversion update
The speedpro/ford dogbone conversion in project Frankenstein now has about 3000 street miles and has been abused a lot and the lifter conversion is working beautifully and is quiet as a mouse. Has many 5800-6000 rpm hits on it. this combo is a 400 based 461 with Jim Hand ported 6x heads, 237/243 at .050 Howards hydraulic roller, and Holley terminator fuel injection. Im very satisfied at this point and will be doing another one in the near future.
The Following User Says Thank You to 68hotbird For This Useful Post:
  #171
Old 11-26-2021, 06:34 PM
68hotbird, when you do the next one could you do a little write up with some pics, please? I’d like to see exactly how you go about this.
Murf
The Following User Says Thank You to Murf For This Useful Post:
  #172
Old 11-28-2021, 05:01 PM
I have a lot of pictures from this build what specifically are you looking for?
  #173
Old 11-28-2021, 06:06 PM
Just general stuff. How far the links are ground & where. Did you attach the spyders back together or are they two separate pieces?
Murf
  #174
Old 11-28-2021, 07:55 PM
Default Spyder
spider is 2 separate pieces. All of the grinding is on the bottom side on an angle. I also milled .030 off the underside of the dogbones to keep the lifters from raising them up at max lift.
  #175
Old 11-30-2021, 04:23 PM
tempest1964's Avatar
tempest1964 tempest1964 is online now
https://forums.maxperformanceinc.com...=847708&page=9
As an additional piece of info, 68hotbird posted these photos of his mill modification to the dog bones. It is post #166. Thanks 68hotbird!
  #176
Old 12-01-2021, 09:12 PM
I'll add you might check your block and see if it has a cast in rib between the lifters. My block had a vertical rib running between the pair of lifters and was the biggest obstacle in fitting the dog bones. In checking the pics I could find on the dog bone conversions it did not appear that those blocks had the cast in rib. Several of my dog bones were in the .070 thick range and I wasn't comfortable with them that thin.
On a good note, I have the johnson lifters installed and the pushrods are ordered and should be here tomorrow. I hope to have the valve train buttoned up this weekend and finish off the rest of the install.
If all goes well I hope to drop the motor in the chassis the week of the 11th!!!!!!
  #177
Old 05-09-2022, 10:20 AM
Karl Rich Karl Rich is offline
Default Update on the Ford Spider HT2148 modification.
Can we get a update on the Ford Spider HT2148 modification, I have purchased all the parts but have not pulled the trigger on installing them yet. Seems that the threads on this modification have cooled down. I won’t to go with the plate at first but
did not see a lot of good reviews on it.
  #178
Old 05-16-2022, 03:50 AM
Tim Corcoran's Avatar
You know, nothing wrong with link bars. In fact top fuel funny cars and top fuel dragsters use link bars on their roller lifters so must not be such a bad design.
Tim Corcoran
