#101
Very impressive numbers and a beautiful looking motor! My garage door is always open if you get tired of playing with it! LOL
Sent from my iPhone using Tapatalk |
#102
Final numbers with the RPM were 600tq starting around 3600rpm, peaking at 640tq around 4500 and peak hp of 608 at 5800rpm
The Following User Says Thank You to slowbird For This Useful Post: | ||
#103
Great job! You put that Performer RPM to good use.
#104
Wow, great numbers, Was the Performer RPM worked over or just a port match to the head?
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
#105
Plenum work and port match
#106
Great numbers,
that 69 GP should really scoot. Is it an auto or manual car? How is the idle quality and vacuum at idle? Again, Very Impressive wide band power. |
#107
Auto, on the test stand it had around 16" vacuum
#108
It should actually get decent mpg..depending on carb tune car weight and gearing.
#109
Interesting that its making that much vacuum. I recently got mine running also. Cam duration is almost the same. A little less lift. I'm only reading 8-9" vacuum idling around 800 RPM. Will get it on a chassis dyno after I get some bugs worked out with the EFI.
1979 TA 541/T56 Magnum 1964 Catalina 462/TKO600 1965 GTO 389/4speed |
Thread Tools | |
Display Modes | |
