America baby. I would not trust a valve or a seat made in CHINA on my engine. Let alone the machine work installing the seat. Or the springs for that matter. Might want to put a small flashlight under a Speedmaster seat and see if you can see some light. |
Dyno Time
Hope this works this time
GT |
More Dyno Time
OK here is the two dyno sheets, Read them and weep LOL
GT |
Speedmaster Motor
[QUOTE=ponjohn;6261087]What is the whole combo?[/QUOT
OK-Stock valves new springs by Pac $275.00 at the time. Allum rods fro a member here with bearings .040 SRP pistons From a member here and rings and installer, Thanks guy's for The rods and pistons. Polished factory N-crank, Solid roller cam From another member here on the PY 638 lift 275-279 dur@50 Wensler tunnel-ram with two carter 750's MSD-ignition 34 degrees Total timing.11:37:1 comp, Deep sump pan with a 60-pound pump Double Roller chain+gears. I ported the heads myself, I spent two day's On them. There is still a lot more in the heads to make more power. Maybe later. GT |
Sorry , Both are blurry.
E-Heads
[QUOTE=blueghoast;6261303]
The E-Heads I bought new 2.19x5.3ish 1.77x5.245 I think.Fearra valves. New Pac springs also around $275.00 plus the $1407 for the heads and It was a $1000.00 for the porting Longer rocker studs I had the titaniam Retainers , Ross pistons pins and rings already had, Eagle Rods from PY member Turned N-crank Victor intake with 1050 Dom and carb spacer. 83-91 jets Solid Roller cam and lifters, Cam from a guy at Norwalk 626 lift 274-279dur @50 60-pound oil pump with deep sump pan 12:98:1 comp. Both motors have MSD distributors and same 2-inch headers 3.1/2 colecter I believe thats it other tenn the total prices. GT. |
The Following User Says Thank You to blueghoast For This Useful Post: | ||
I'll see if I can take some better ones
GT. |
Buddy's Motor
I almost forgot my buddy dynoed his motor the same day I did mine
His made 626 HP and 580 torqe, 13:03:1 comp E-85 and a vacume pump. Hyd roller Hyd roller lifters 610 lift 264-266 dur@50 400 block 425 stroke Crank the cheaper eagle rods Good file fit moly rings pistons look SRP Pistons can't remember name, His heads flow 318 CFM and they are the Speedmaster heads also, Stock valves MSD also. I get his dyno sheet on Here to when I take to him He run's a victor and 4150 style carb. GT. |
New Dyno Pics
Should be able to see better this time.
GT |
The Following 2 Users Say Thank You to blueghoast For This Useful Post: | ||
Both combos should be making more power. Mismatched parts. Cams are too big for what you get back. Not a good test, does not prove anything other than less money.
Need higher end efforts to get a good idea of their potential. Sorry. |
Im kinda of a made in the USA guy..........!
GTO George |
The Following User Says Thank You to GTOGEORGE For This Useful Post: | ||
More power from 300cfm? |
He is just posting the results, not asking for opinions.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
+1 Mike. Blueghoast thanks for taking the time to post your info. I, for one, appreciate it! Murf Sent from my iPhone using Tapatalk Pro |
The Following User Says Thank You to Murf For This Useful Post: | ||
I agree. Someone asked for results with SM heads. He didn’t ask for opinions.
I agree with this...I wish I was more familiar with who is who on this site...That would make it easier to know what their opinion is worth.
On pump gas hauling doing Drag Week hauling a trailer with all your Goodies driving a thousand mile's a week and make it trough it all. Yes with more porting and better intakes (mine are off the shelf) And better carbs and maybe more cubic inch's, But both of these Motors were built with used parts good part mind ya but still used. Lets see what kind of power you can make. Since I've dynoed a Couple motors I know it's not that easy to make 600+ HP. Show us your dyno sheet when you do your motor and we;ll evaluate The power you make and I will applaud or I will ride your ASS LOL GT. |
The Following 3 Users Say Thank You to blueghoast For This Useful Post: | ||
#38
I agree Mike. Blueghoast thanks for taking the time to post your info. I, for one, appreciate it! And it is their project and just sharing the results.
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
The Following User Says Thank You to Jim Moshier For This Useful Post: | ||
#39
Thing is, if you can not make 600+ HP on pump gas(E85, 13-1, not really) .264 roller cam with 318cfm heads something is wrong. I mean, its going to unless the cam is 8 deg retarded.(buddys engine) Your engine has two fours on a tunnel, 1400 cfm of carb with a .275 @ .050 cam and 11.37-1 CR. Its simply going to make 600+ HP unless something is very wrong. You did port them yourself, saving money. Nothing wrong at all with the power you are making. Just not a high end enough build to give a strong "opinion" as to these Chinese heads are better than our USA Edelbrocks. The 461 I am building at this moment will not see a pump. It will see weight, ET and MPH and go from there. No used parts, well thought out Sparred little expense. Cam I am using made 815 and 865 HP on pump gas 535 and 505 engines. And will post what it does when ironed out and folks can say what they want no problem. To me I would need to see a "wow" engine before I would think those Speedmasters are any better. Have not yet I need that before I throw my country under the bus on this. |
#40
Unless someone wants to go through the time and expense of welding them up and re drilling pushrod holes. The Ti valves (can SM take 2.25 ") the epoxy, the max effort. Not happening. Maybe I am wrong but I doubt we will ever see a Barton, Marcella or Gabby Speedmaster max effort head. I would trust their opinions on how much power, how good those heads are. |
