#61
Thats what I thought to, I beleive it's got to do with the cam events.
Though it does seam low with that much compression huh. GT |
#62
... this is my 10.6 to 1 428 build, CV-1's and 93 octane, it made well over 700hp ... ... simple combo really ...
"DON'T BE A CV-1 HATER... IT JUST MAKES YOU LOOK STUPID" |
#63
bore and stroke? RPM of peak power and torque? valve sizes? rocker ratios? |
#64
4.00 stroke 7300rpm HP peak 2.190/1.75 1.7/1.7 rockers
#65
more pics ...
#66
How has it ran at track? Just curious how the stock block is holding up.
#67
X 2
#68
Is that a 290 cc intake port? Thanks, Stan
#69
... my car is still getting the suspension work and cage work done at the chassis shop, the engine only has dyno time so far ...
#70
... yes, that top end was sold, it went 9.0's on a 535 single 4 set up in a 3300lb car, but broke the transmission, so hopefully the new trans will help some too ...
... my engine is getting an as cast CV-1.1 top end on it now ...
