How to route positive battery cable to starter?
I've got my new 461 in the 66 Tempest, headers on. Went to install the starter last night and it's a very tight fit but it's in there. Since this is my first Pontiac motor, how do you route the positive battery cable up into the front of the starter? Does it clip to the crossmember? Obviously I don't want it to be too near the headers and a ground!
I will be installing the battery in the trunk so I can have the cable come through the firewall/floor wherever makes sense. I can't imagine how I'd do it with a normal battery tray. I know a mini starter would help with this and heat soak but it's not in the budget right now. Trying to just get it running. Sent from my SM-G988U1 using Tapatalk |
The (+ ) batt cable usually runs along the oil pan and then up the front of the engine to the battery. There were a couple different brackets/tubes the factory used. The (-) cable attaches to a head bolt stud, or another threaded hole in the drivers side cylinder head. I'm unsure how this would work with a batt in the trunk.
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
You need part # N179EK(battery cable heat shield $34). This is bolted to the driver side motor mount. You have to drill and tap the mount. You will also have to bend the battery cable where it comes off the starter(90*) for max clearance. In order to install it you will need to drop the starter and attach the cable after first running it through the tube that is attached to the motor mount.
https://secure.amesperf.com/qilan/De...A&web_access=Y
Nice flywheel !
3 Generations of "Beach Boys Racing" ! Everybody knows somthin. Nobody knows everything ! 1st time on a dragstrip, 1964. Flagstart ! "Thanks for the entertainment." "Real Indians Don't Wear Bowties" |
I would use a ford solenoid.
The Following User Says Thank You to ponjohn For This Useful Post: | ||
Lol, it does look like it’s on backwards! Sent from my iPad using Tapatalk
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
Appears to be that way doesn't it.
Is this a fresh build with the engine/flywheel/starter/bellhousing? I got away from the stock tube thru the exhaust manifold on my 64 GTO and went to the 67+ style, (go under the manifold/ (headers in my case), along side the block and then down to the starter. Tom V.
The Following 3 Users Say Thank You to Tom Vaught For This Useful Post: | ||
Aw crap, is it on backwards? How embarrassing!
Yes, fresh build and my first. Not my first mistake in all this if I did put it on backwards... Here's hoping there aren't others Sent from my SM-G988U1 using Tapatalk |
Oh man, you guys had me freaking out. I really don't want to yank that motor again. I watched a Ram clutch install video and the flywheel teeth are on the motor side, not the clutch side. I pushed the starter gear out and it seems centered on the flywheel teeth. I think I'm good, right?
More pictures attached. Ram 1557 flywheel and Ram 11" powergrip single disc clutch. Sent from my SM-G988U1 using Tapatalk |
Picture is worth 1000 words. Yep, you have it on correctly.
Sometimes a picture can be deceptive. Why made the flywheel? Looks like a nice one. One nice thing about a stock Bellhousing, you can see the flywheel/clutch parts from the bottom of the bellhousing if the metal shield is not installed.. Tom V.
Thanks for confirming!
https://www.youtube.com/watch?v=L2Aurj3YoxY
I know, I know. BUT I do this on all my older cars to get a way to remote crank my engine AND get that live battery cable away from all the hot things.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge Last edited by SRR; 03-19-2021 at 03:48 PM. |
The Following User Says Thank You to SRR For This Useful Post: | ||
