67 Ram Air on Ebay
The Following User Says Thank You to Sloan66 For This Useful Post: | ||
It is also listed in the forum for sale area, nice car
Very rare car in good condition.
I don't have much experience with California cars, Wasn't aware they charged so much for the AIR stuff on them. Guessing the heads have been changed on the engine - no signs of AIR provisions. Which version of heads would a Nov 66 build have gotten ? |
with four ports each threaded into the exhaust manifolds? Pontiac kept things much cleaner by just using brackets mounted on the front of each head. HTH. |
My notes for 67' YR shows 97 heads with AC.
Bet it's suppose to be AIR instead of AC. ???? Clay |
AIR
All 670 heads have the AIR passages. You can see the cast-in passage that goes the length of the head just below the valve cover. The '67 RA cars used a mix of heads. The first were modified '670 castings the later heads had a unique casting number (which I cannot recall). Notice the EUN on the PHS matches the engine stamp. Very unusual to see a real-deal "matching number" 4-speed RA!!
Very rare car indeed. Here's what the smog system looks like on the CA RA cars. |
The Following User Says Thank You to DANTIP For This Useful Post: | ||
I was thinking semi-chevy type system with lines tapped straight into the heads at the machined bosses on the rail below the valve cover area.
Years ago read that was what the provisions were for, but i guess Pontiac one-upped that layout. Thanks for the pictures and explanations. Supposedly there were 3 versions of heads used. 670 with no outer mods 670 with 6 and 0 ground off - and 99 stamped alongside the 7 Then finally a cast 997 head. The only 2 cars i have seen both had the ground off version. Probably call this one on the tail end of an "early" RA 67 car. Only 64 YR cars produced according to end of year engine production stats. YQ (Auto AIR) doesn't even have a stat listed, may have been 0 Also think the YR code threw some bid prospects off track thinking it was an Automatic converted to 4spd its a wacky code |
Here's a photo showing the open passage ports just outside of the freeze plugs. They are threaded for screw-in plugs on cars without A.I.R..
The Following User Says Thank You to 428ho4spd For This Useful Post: | ||
1) Aluminum alternator bracket with provision for Smog tube. 2) Double pulleys on alternator. Plus the heater hose attached to the RH fender skirt. The ‘67 illustration showing both cylinder head “plugs” that would be removed for the A.I.R. system, plus the special aluminum bracket. Looks like there is at least “1” of the ‘67 R/A with automatic and A.I.R. (YQ) which was a test car.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. Last edited by 60sstuff; 08-15-2020 at 05:25 PM. |
The Following User Says Thank You to 60sstuff For This Useful Post: | ||
K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
I don't know what to think about how they didn't list out YQ
The penciled in notation is way after the fact, by Fred. They would have been produced stamped & long-blocked in Michigan Oversight or Zero ... idunno I suspect bigger buyers aren't as attracted to a YR coded car with plain looking 670's. XS with later heads would be the golden geese. I can kind of relate to that Color change was odd to Silver I'm not a Gold fan either though He's got an ultra rare 67 GTO I would get together a better detailed in-depth description, include more pics and info about the completeness of the AIR and Carb, and list it on Bring-a-Trailer. |
Great car with original motor. Just needs a total resto in my opinion. Worthy
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of! |
I Agree, Full Worthy
But i'd settle for an underhood detail, trunk floor fluffing, and a set of Rally Ones . Maybe a set of ladder bars Glasgo didn't you have a Plum Mist 67 R/A car ? |
Did all 67 Ram Air's get the 744 cam?
No. Would love to
Somebody posted a few pictures of a 67 Plum Mist R/A car a few years back and can't remember who it was now.
Have only heard tale of maybe 12-15 of these cars in the last 30 years. I think another PY member has an Automatic (maybe White iirc) |
Mr. BVZ,
Here ya go. Supposedly a 67 R/A in Plum Mist. Suspended member. CT
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
Damn
CuznGreg owned it He's owned about one of everything except a Ram4 JudgeVert and TA Vert Believe its the same car as my picture too. 5-6-7 years ago there was a Tyrol Blue 4spd RA with a longtime owner on eBay. maybe even the original owner Had 69 Ram4 head upgrade back from when Ram4 came out. The bids started going up and he got cold feet and ended the auction. Never heard anything else about it. |
That was a dark blue car. I had just bought a low mile 67 when this popped up. I should have bought it. It was really cool!
