#41
#42
Purolator PBL25288 is SMALLER than WIX51238.
How can that be a problem? |
#43
First Guess: Excess oil pressure distorted the filter, the oil pressure bent the top enough that the gasket can't seal. Figure out why the oil pressure is enough to distort the oil filter. Stuck pressure-relief valve in the oil pump is the likely suspect. |
#44
The WIX is clearly larger, if you took the time to look up the dimensions. The WIX is 4.338" tall and the Purolator is 4.13" tall. Diameter is 3.66 vs 3.56. Next question? |
#45
I got the dimensions from Amazon. They must be wrong. I am just looking for the best filter I can fit without jumping thru hoops
#47
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
#48
The truck ran 15 flatish after the filter change. The computer did drop the rev limiter from around 6100 RPM all the way down to 5400RPM. You can disconnect the battery overnight and the truck runs fantastic. Then the computer slows it down if you hammer the gas. Actually this computer controlled fly by wire bu!!cr@p you can not be consistent with your lights and the ETs vary so much its not worth trying to win. Not going to chip the truck, throttle cable and a carb, that's drag racing. |
#49
https://www.wixfilters.com/Lookup/filterlookup.aspx Maybe you should bookmark this site.... |
#50
I would look at Wix 51522 or ACDelco PF61 or Purolator L, LP or PBL25288 which all are the smaller 1999-2004 Cadillac filter for headers clearance. Hope this helps some. |
#51
#52
It's been a little while since I've used the K&N oil filters, but, when I did, one thing I noted was that at that time, they did filter to a smaller micron, and, because of that, clogged faster, and around 1500-2000 miles, I saw a noticeable reduction in oil psi.
In the 80s, I found out Fram was not the way to go. Most of the parts store stuff was garbage, except for a few, such as ACDelco, Motorcraft, and some of the mid-line NAPA stuff. ACDelco had a bad run when they moved production the MX, but they realized that, and fixed that issue, but some of the damage was already done (user confidence), and it took a while to clear out the warehouse stock. I run FP24s, never had a psi or flow issue. Yes, I have compared filtration ratings, but some think that more is better, which is not always true. Think about it, you run a .0026-.0028+ bearing clearance, explain to me how filtering down from .0009 to .0003 is going to make a difference? At that point, the psi/flow is going to save you way before the filtrations level. And most still change oil at 3k miles anyway, so there's limited risk of 'clumping' or build up. . .
#53
Part of the explanation from Jeff Smith, of why fine abrasives are the reason for wear in engines: Quote:
I've said before many times, the oil filter position is a compromise, which can't be made to keep the small abrasives out of the oil, and still supply adequate oil volume to wear surfaces, really simple. To help this shortcoming you have to keep flushing the small particulate from the engine by frequent oil changes. It's expensive, and as soon as you put fresh oil in, the small particulate starts it's cycle over again of contaminating the fresh oil. Removing the fine stuff from the oil on the first pass really minimizes the wear effects. Problem is full flow filters cannot ever remove the fine material no matter how many times the oil passes through the full flow filter. A seven fold decrease in wear is fairly substantial, just by removing the abrasives a full flow filter has no way of removing. There's an obvious answer to the problem, and I'm not going to belabor the answer. |
#54
I've got a new Wix (NAPA Gold) on and the leak is stopped.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning. |
#55
The PF24 that I had on my engine on the break in stand leaked.
#56
Why did it leak?
I´ve been using the PF24´s for at least 30 years and not one has leaked. |
The Following User Says Thank You to Kenth For This Useful Post: | ||
#57
I too use the HP2006 for close quarters with Dougs headers on 1966 A body.
#58
I just got the Purolator Boss. It is much smaller. Looks like an LS filter but it looks like it will work. As far as the Pf24 I don’t know why it leaked. I have never had one leak either. It was however old stock from a closing part store so maybe the gasket?
#59
And in those tight spaces - having that lug on the bottom helps get it off.
