Old 06-16-2020, 09:52 PM
jotrout jotrout is offline
Default Mickey Thompson Tires
Guys,
I need a sanity check here with a purchase I'm considering. On my 66 GTO I'm now running BFG 275 60R 15 in the back and want to replace them with MT Sportsman S/R. MT lists the size as 26x12R15LT. I believe the stock height is 26.1" or there about and the MT's are 26". Is this the correct replacement size? I have no rubbing or modifications needed running the BFG tires as I station wagon springs in the rear that raises the rear up nicely. I'm planning to run 15x8 Crager rims with 4.5" BS.
I tried calling Jegs & Summit today but the phone lines wouldn't connect as they normally would. Thanks!
Old 06-16-2020, 10:42 PM
quick67bird's Avatar
quick67bird quick67bird is offline
A 275/60/15 tire is roughly 27.9” high to 28.1” high depending on manufacturers. I believe 9.8 to 10” tread width. Section width is wider depending on rim size.
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 06-16-2020, 10:48 PM
Not sure I have the correct tire then. The specs for the MT
Tire Overall Diameter: 26.1''
Tire Tread Width: 10.6''
Tire Section Width: 12.0''
Wheel Diameter: 15''
Spec Wheel Width: 10''
Approved Wheel Widths: 8.0-10.0''
Tire Weight: 26.0 lbs
Old 06-16-2020, 11:04 PM
https://www.summitracing.com/parts/mtt-6640
This would be closer to a 275/60/15 tire.
Old 06-16-2020, 11:06 PM
https://www.summitracing.com/parts/mtt-6641
This one is a bit wider, but same height.
Old 06-17-2020, 12:07 AM
Thank you Quick67bird. I can see these are the tires that'll work.
Old 06-17-2020, 12:20 AM
You are welcome. I am thinking of getting a pair of these for my Firebird LOL.
Old 06-17-2020, 12:24 AM
Further research on Americas Tire site shows they'll be an increase of 1.17" if I go with the wider 6641, which I like. The question is will the 1.17" be on the outside or inside of the tire or is it split down the middle.
https://www.americastire.com/learn/t...200617041250:s
I can go a good 1" to the outside but have 3" exhaust and the tail pipe would be in the way. I could modify it but just asking. Thanks
Old 06-17-2020, 12:56 AM
Split down the middle with current rim backspacing. .585” to the lip and .585” towards the inner wheel well.
Old 06-17-2020, 01:57 AM
Schurkey Schurkey is offline
26x12R15LT
You want Light Truck tires?
https://www.goodyearautoservice.com/...sics/tire-size
The letters "LT," either at the beginning or at the end of the tire size indicate the tire was designed for light trucks.
Old 06-17-2020, 10:01 AM
Navy Horn 16 Navy Horn 16 is offline
That's a Nitto 555 on the left next to a MT ET Street Pro. Both tires are 275/60/15.
77 Trans Am, 469 w/ported E-Heads via Kauffman, matched HSD intake, Butler Performance forged rotating assembly, Comp custom hyd roller, Q-jet, Art Carr 200 4R, 3.42s, 3 inch exhaust w/Doug's cutouts, D.U.I. Ignition. 7.40 in the 8th, 11.61@116.07 in the quarter...still tuning.
Old 06-17-2020, 12:49 PM
Yikes! Thanks for the heads up!
Old 06-17-2020, 12:52 PM
Thanks for Nitto 555 comparison. That one will fit
