I need a new cam and am thinking about Summit's own cam and lifter kit. This will be used going to shows mainly. 1966 LeMans 326 HO 4 speed 2 1/2" pipes.
I have used them a few times with no issue.All have been 2801.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
Same here. No issues and great price.
I bought a budget one for my trail beater 304 CJ5 as the orig cam went flat several years ago, still doing fine.
Two 1975 455 Grandvilles & '79 455 Trans Am ‘69 Camaro SS 396/375 (owned since ‘88) ‘22 Toyota Sequoia V8 ‘23 Lexus LS500 awd ‘95 Ford F-super duty 4wd 7.3 p-stroke & countless Jeeps & off road vehicles. |
it's probably a good idea to buy better lifters. i've had one go bad, cam showed little wear, lifter was toast. Buy American.
I have a 2801 in the 400 in the 81. Degreed right on the button. Has the sound and power of a 068.
2801 here as well but run the Melling JB951 lifters as they have the cast iron faces or maybe I am incorrect as Truman Fields calls them "iron chilled?"
I just put one in a BBC, haven't done anything but break it in, but so far seems fine.
I've used 15 - 20 of both the 2801 and 2802 cams and lifters. Never had a problem.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
I've got a 2801 cam/lifter set in my 400. No problems at all.
I know it's been mentioned Summit's parts suppliers can change over time. I bought and installed the cam about 7 years ago. Not sure if they're still using the same specific suppliers for these sets today? |
No! Do not try! Do! Or do not. There is no try. - Yoda 1967 Firebird Restoration 2005 - 1/25/2017 ![]() |
The Following User Says Thank You to Speargun For This Useful Post: | ||
