Old 01-25-2020, 12:06 AM
slowbird's Avatar
slowbird slowbird is offline
Originally Posted by Rusty4cyl View Post
Dragncar Yes they have a shaft rocker set up for them. I used to run a wide port Edelbrock head and I had Dave do another Edelbrock wide port head to see what the difference would be. With everything the same except the head I picked up 40hp at the wheel's on a chassis dyno, so yes Dave know's what he is doing. And I am sure this head will be a lot better than the CV -1 I have. Yes I am still trying to sell that head too. Thanks Rusty
Which is better cv-1 or wide port e-heads?
  #222
Old 01-25-2020, 12:14 AM
Rusty4cyl's Avatar
Rusty4cyl Rusty4cyl is offline
I think Dave's wide port Edelbrock is better. Thanks
Blown 4cyl's to the front
  #223
Old 01-25-2020, 12:16 AM
slowbird's Avatar
Brian,
They look somewhat like the GM LS Cathedral Intake Port. But since the push rod is not in the port how wide can he go before the push rod angle makes valve train geometry a problem?
Stan
All good questions
  #224
Old 01-25-2020, 12:18 AM
slowbird's Avatar
Interesting, thanks for sharing
  #225
Old 01-25-2020, 02:05 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Scott Roberts View Post
... why would someone spend the money on billit head to only make 15oohp...
Knowing Dil, I can see where a hemi fits well with his "Gasser Gang" image.
  #226
Old 01-25-2020, 03:04 AM
Dragncar Dragncar is offline
So if it picked up 40 HP at the wheels would 60HP at the crank be a reasonable guess for the horsepower increase ? From a basic "cookie cutter" wideport to one of Daves high end ones,NICE!
At any rate 40 or 60 horsepower jump in a 4 banger is quite a jump. If it was done on a big V8 even ore power.
I would say Dave Wilcox knows what he is doing.
I asked him if he could get 400+cfm out of High Ports with std pushrod and 2.20 valve and he just said "yes". I might give him a crack at it. Its like high end E wide port performance but no offset stuff or huge valves. Stud girdle and go.
  #227
Old 01-25-2020, 10:55 AM
slowbird's Avatar
That's some pretty fuzzy math.
A 400cfm standard pushrod HP head is nothing like a 400cfm wide port e-head.
  #228
Old 01-25-2020, 12:06 PM
The Wilcox ram air 5 heads I have coolant runs through. 2 separate passages on each head on intake and exhaust sides front to rear.
  #229
Old 01-25-2020, 12:43 PM
Stan Weiss's Avatar
Brian,
Hasn't Dan Barton gotten 400+ cfm out of a KRE HP with standard push rod location?
Stan
Pontiac Pump Gas List
  #230
Old 01-25-2020, 12:51 PM
slowbird's Avatar
Brian,
Stan
Real close to it
  #231
Old 01-25-2020, 01:27 PM
PAUL K's Avatar
PAUL K PAUL K is offline
If you are looking for all out performance a 400cfm wide-port will make better average power than a 400cfm standard pushrod location head more times than not.... A LOT more to it than "CFM"!
Go fast, see Elvis!
  #232
Old 01-25-2020, 01:40 PM
slowbird's Avatar
I'll take a 370cfm wide port e-head (if done right) vs a 400cfm standard pushrod hp head
  #233
Old 01-25-2020, 01:44 PM
Stan Weiss's Avatar
Paul,
Would you be willing to share what kind of CSA each head has?
Stan
  #234
Old 01-25-2020, 02:10 PM
PAUL K's Avatar
Paul,
Stan
No....but it's not only the cross section size but where the smallest area is placed. It usually ends up at the pushrod pinch point, head bolt bulge or valve seat area.
Go fast, see Elvis!
  #235
Old 01-25-2020, 03:58 PM
slowbird's Avatar
Paul,
Stan
Just a guess but i'd bet the difference is .3-.4 sq inches
  #236
Old 01-25-2020, 06:18 PM
Hey, I fully understand its not going to have the CSA of a big wide port head. But, I am a bracket racer and both would more than do what I want to do with them.
I don't think the std HP head would make as much power on a equal footing. It is a smaller valve and smaller choke point.
But does it matter ?
  #237
Old 01-27-2020, 04:53 PM
GTOGEORGE's Avatar
Some pics of Dil's Hemi Head!
GTO George
ID:	530181   Click image for larger version
ID:	530182   Click image for larger version
ID:	530183   Click image for larger version
  #238
Old 01-27-2020, 05:36 PM
GTO George
Cool George. Are there any with al the rockers on ?
The holes for the spark plugs do not go down the center of the valve cover. Are they close to the middle of the chamber ? Any chamber pics ?
Thanks.
This stuff has to start out somewhere. I think a engine like this is a good start vs trying to make huge power right off the bat.
  #239
Old 01-27-2020, 06:22 PM
Stan Weiss's Avatar
I would like to see a picture of the combustion chamber also.
Stan
  #240
Old 01-27-2020, 06:24 PM
GTOGEORGE's Avatar
Stan
Thats it, its all I gots right now.
GTO George
