SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference.
Old 01-12-2020, 05:01 PM
Lenox273's Avatar
Lenox273 Lenox273 is offline
Location: California, KY. 30 miles south of Cincinatti, Ohio
Default Powertrax no slip locker for 8.2”
Used no slip locker. Worked fine, just swapped to posi unit. Has about 890 miles on it. Asking $225 shipped in the lower 48. Have manual and install and install instructions. https://www.summitracing.com/parts/pwt-92-0782-2801/
Old 01-12-2020, 06:14 PM
Lenox273's Avatar
Located in northern Ky.
Old 01-14-2020, 03:20 AM
CatalinaMike CatalinaMike is offline
How did you like this unit? Is there a reason you changed to a posi?
Old 01-14-2020, 07:32 AM
Lenox273's Avatar
It was ok. I knew from a lot of research going in that it would be noisy and change the way it went through turns. I’m getting ready to sell the car and knew potential buyers would most likely not care for the characteristics of it. Switched to an Eaton posi. Much more pleasant to drive now. The locker was to be a temporary fix til I could upgrade to a stronger rear end, which never happened.
Old 01-14-2020, 01:51 PM
I thought they had fixed those issues. That stinks they didn't
Old 01-14-2020, 08:27 PM
Lenox273's Avatar
I do not know how it could not make noise by the way the gears are designed. Really don’t hear it while driving. Mostly hear it doing parking maneuvers.
Old 01-14-2020, 09:01 PM
What gears size were you running? I have 3.55s
Old 01-15-2020, 07:28 AM
Lenox273's Avatar
3:23. Gear ratio doesn’t matter with this unit like it does with a complete carrier. You just need to have a non posi carrier. If your interested in this pm me and we can discuss.
Old 05-18-2021, 07:22 AM
mrod67 mrod67 is offline
Is this still available? Ive got a skylark that summit says it would fit
Old 05-18-2021, 11:11 AM
I have a locker in my car works awesome in a straight line you would think the rearend is broken driving around or turning if you didn’t know it was in there.
Old 05-18-2021, 12:08 PM
Lenox273's Avatar
Mrod , it has been sold.
