I've had the exact same issue with machine shops using wrong bolts, also for the oil deflectors under the valve covers.
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 Bonnie Cvt & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
Here is a picture from my 71 TA after removing the engine for the first time in 2006. The positive cable was retained by two clips, one in front and one behind the left motor mount. The yellow arrows point to the clips, not to be confused with the starter motor bracket that is outlined in red.
That is the incorrect clip. I have made both the front and rear clip before, quite easy. Just get dsome sheet metal, cut strips, bend it ,then dip in liquid rubber.. Butthe one you show in this picture is the incorrect clip for the front and rear motor mount clip.. FWIW>.The front clip is different than the rear clip..
Are there battery cable retainers made from spring steel? Should be easy to make as described above but how does steel get it's springability? Heat, oil quench or...?
John '68 Firebird Ram Air 4-spd Conv. John 14:6 Semper Fi |
