Old 11-18-2019, 08:06 PM
grd777 grd777 is offline
Default found a real nice sub frame but?
picked up a sub frame from my buddy , (he has to move and no room to store it ) it is very clean and seems to be better than the one i got .But what i see is that the engine to frame bracket are welded in and a bit farther back thne mine , is this from a 6 cyl car . he said it came for a 1971 car
Old 11-18-2019, 09:04 PM
4dblnkldude's Avatar
I would think the V-8 bracket holes would still be there. Cut off the mounts and check.
Old 11-19-2019, 09:48 PM
Formulabruce's Avatar
6 cylinder mounts are up near the front more than the V-8's
Old 11-19-2019, 10:39 PM
can i send you a photo so you can let me know what it is
Old 11-19-2019, 10:46 PM
Post it up! Lets see the subframe !
Old 11-19-2019, 10:48 PM
do not know how
Old 11-20-2019, 01:04 AM
Default Test post pic.
Click Go advanced, below.
Then over to left and down click "Manage attachments"
Next select the file off your computer or phone if its plugged into your computer,
or from the galley in your phone.
Then click the "upload" button on the right side of the box.
ZThen in middle BOTTOM of that box click "Close box" . You may have to scroll to bottom of the box.
Then click "submit reply" at bottom of the post you are making. You make make a title up top before you submit.
Name:	1970 Formy.jpg
Old 11-20-2019, 01:12 PM
hereu go
Name:	IMG_2373 (002).jpg
Old 11-20-2019, 10:59 PM
This subframe may have been used on a street rod with Pontiac power. Looks like a typical '70 frame with all the holes for both the chevy 6, and the Pontiac V-8. I have marked the picture up to what I think It should look like when all correct. Others here may chime in with their thoughts too.
Name:	frame mount 2.jpg
Old 11-21-2019, 05:12 PM
I thought that they were wrong. What about the frame bracket are they ok for a 400 engine because when I tried one of the motor mounts it seems that my motor mounts are much wider the the frame brackets (were the bolt goes through). Or do u have a correct set to sell
Old 11-21-2019, 05:45 PM
The mounts welded on look like 70-74 Pontiac engine mounts, however these could have been and probably were cut at the area where the bolt goes through for some other engine mount to fit. The frame side mounts might be reproduced by now.
Old 11-21-2019, 06:49 PM
That makes sense. Should the motor mounts fit snug to the frame mounts
Old 11-21-2019, 07:05 PM
Bentwheelbob's Avatar
This picture may help. It matches what FB showed as the correct location. The frame and motor mounts should fit snug. It appears yours were the correct mounts, but for some reason they were modified by trimming each side where the motor mount mates with them and the bolt passes through. I have a set of frame mounts for sale that have been powder coated and come with bolts. $225 shipped CONUS. To my knowledge they are not reproduced.
Sent from my iPad using Tapatalk
Old 11-21-2019, 07:44 PM
Do you have the long bolts for these also. I live in Toronto canada
Old 11-21-2019, 09:47 PM
Yes and I’ll throw them in the deal if you pay shipping difference between Buffalo, NY and Toronto. If you are interested, text me at 304.859.7509. Thanks.
