Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
X-Mass Bump.
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
Remove the o rings and epoxy I have several friends running cosmetics after doing this no issues.
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
McCarty RA-V Heads BARE 356T-6 Alum 81cc
O-Ring Dry Deck CNC Combustion Chamber CNC RA-V Head Porting Alternate Intake Valve Spacing Intake Valves Victory Stainless Severe Performance 2.300 diameter Exhaust Valves Victory Super Alloy Inconel 1.750 diameter Intake Valve Seats Special T hard seats Exhaust Valve Seats Special T hard seats Valve Guides PPP Special "Tool Steel" guides Valve Spring Cups Manley 42371-16 10 Degree Titanium Retainers Manley 23640-16 Valve Locks Manley 13162-8 Lash Caps Nitrosteel Victory VLC-341125 VALVE SPRINGS Manley 221425P-16 ARP Head Studs T&D Stainless Shaft Rockers with all the options Smith Brothers Push Rods for T&D Shaft Rockers Single Plane Intake Manifold Dominator McCarty RA-V Intake Porting Borla Fuel Rails 10K Also have a few other misc parts if the higher end pieces are not required. Valve Springs Manley Nextek Manley 221424-16 Pushrods Manley 25374-16 Rocker Studs ARP Pro Series 7/16 diameter Pushrod Guide Plates Comp 4835-8 Turbo Headers 321 Stainless IndyCartel Camshaft LSM CIN#Y027 Standard Firing Order, 255@.050, .425 lobe lift. ~700 gross w/1.65 rockers Lifters Solid Roller Crower 66260-16 Timing Chain US Gear Billet
Bump
Available for Pontiac Nationals 2017 delivery.
Bump
Bump for Spring Cleaning.
Camshaft sold.
Norwalk 2018 Delivery Available.
Still Available.
Vintage McCarty RA-V Top End still available. Norwalk 2019 delivery available.
Priced at $0.50 on the dollar, based on racing thread these parts should move
Are these the heads that you originally intended on running on The Raven?
Yes they are.
Why did you switch to Don's instead of running these?
Starts going sideways here -->
http://forums.maxperformanceinc.com/...668432&page=13 I will not support a vendor that does not support their customers and stand behind their product and or services. I did address all issues, but I will not run these parts on the Raven. If you have any questions PM me.
Still available for your winter refresh
TTT
McCarty RA-V Heads BARE 356T-6 Alum 81cc O-Ring Dry Deck CNC Combustion Chamber CNC RA-V Head Porting Alternate Intake Valve Spacing Intake Valves Victory Stainless Severe Performance 2.300 diameter Exhaust Valves Victory Super Alloy Inconel 1.750 diameter Intake Valve Seats Special T hard seats Exhaust Valve Seats Special T hard seats Valve Guides PPP Special "Tool Steel" guides Valve Spring Cups Manley 42371-16 10 Degree Titanium Retainers Manley 23640-16 Valve Locks Manley 13162-8 Lash Caps Nitrosteel Victory VLC-341125 VALVE SPRINGS Manley 221425P-16 ARP Head Studs T&D Stainless Shaft Rockers with all the options Smith Brothers Push Rods for T&D Shaft Rockers Single Plane Intake Manifold Dominator McCarty RA-V Intake Porting Borla Fuel Rails 10K Also have a few other misc parts if the higher end pieces are not required. Valve Springs Manley Nextek Manley 221424-16 Pushrods Manley 25374-16 Rocker Studs ARP Pro Series 7/16 diameter Pushrod Guide Plates Comp 4835-8 Turbo Headers 321 Stainless IndyCartel Lifters Solid Roller Crower 66260-16
#38
PM sent on solid Roller lifters
Carburetor building & modification services Servicing the Pontiac community over 25 years |
#39
#40
Updated:
McCarty RA-V Heads BARE 356T-6 Alum 81cc O-Ring Dry Deck CNC Combustion Chamber CNC RA-V Head Porting Alternate Intake Valve Spacing Intake Valves Victory Stainless Severe Performance 2.300 diameter Exhaust Valves Victory Super Alloy Inconel 1.750 diameter Intake Valve Seats Special T hard seats Exhaust Valve Seats Special T hard seats Valve Guides PPP Special "Tool Steel" guides Valve Spring Cups Manley 42371-16 10 Degree Titanium Retainers Manley 23640-16 Valve Locks Manley 13162-8 Lash Caps Nitrosteel Victory VLC-341125 VALVE SPRINGS Manley 221425P-16 ARP Head Studs T&D Stainless Shaft Rockers with all the options Smith Brothers Push Rods for T&D Shaft Rockers Single Plane Intake Manifold Dominator McCarty RA-V Intake Porting Borla Fuel Rails 10K Also have a few other misc parts if the higher end pieces are not required. Pushrods Manley 25374-16 Rocker Studs ARP Pro Series 7/16 diameter Pushrod Guide Plates Comp 4835-8 Turbo Headers 321 Stainless IndyCartel Lifters Solid Roller Crower 66260-16 SOLD Camshaft LSM CIN#Y027 Standard Firing Order, 255@.050, .425 lobe lift. ~700 gross w/1.65 rockers SOLD Valve Springs Manley Nextek Manley 221424-16 SOLD Timing Chain US Gear Billet Thanks PY!
