His fault.No part of "me" gets under the car in some situation like that. Get the spare first. I carry 2 small 4x4 blocks in my vehicles. If you are jacking up the back you need to chock at least one front tire on both sides. That way the car will not move and fall off the jack.
Its all common sense. |
We're taught at work about the states or errors that cause injuries. They are rushing, frustration, fatigue, complacency, eyes not on task, mind not on task, line of fire, and loss of balance traction or grip. Which ones do you think caused this?
A buddy of mine used to work at Lincoln. They tested all brands of jacks, jack stands, etc. The off-shore stuff would fail under the rating a lot. So, don't "push it".
X2!!! This is the best advice you can hear. Think of this POS spare tire storage idea as a parking brake you NEVER use. Those cable crank tire storage winches rust up in a big hurry in the Midwest. I have cut off dozens of them for replacement. Make sure the tire has air every time you change oil.
Tire under the back was a dumb move by Chevy. They get stolen, fall off, or you can't get it off. I guess you need to do a fire drill on your spare tire situation once in a while in any vehicle you drive. Or have AAA plus and be patient. Being lazy about your spare can bite you in the foot.
Yeah, the tire hung by a cable is not the best idea but many manufacturers use them and it sure beats the alternative.
Out of sight out of mind. Having a tire under there for years is just a bad thing. One day I was trying to pull a stump after I sawed all the way around. Did a good tug on it. Backed up to get some slack in the chain and I backed over something. What the heck? It was the spare. Fell off. Glad it didn't happen on the high way. Check your spares, someone's life may depend on it. |
We had an Olds/Jeep dealer here. They would always back their CJ's up to the left edge of their lot which had a big drop-off. About every other month there wasn't a new CJ on their lot that had rear wheels. After about 2 or 3 years they finally put up a fence.
Being claustrophobic has its advantages.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
I bought a new Yukon last year and, a few months later, ran over a piece of rebar and totaled a tire. I called AAA to get the tire replaced - and a good thing, too. It's so hard to get the tires out now, it would have taken me hours to figure it out.
The tow driver already had the tool for Suburbans - which didn't work for Yukons. Thankfully, many thieves are too lazy to put up with all that stuff.
1965 Pontiac LeMans. M21, 3.73 in a 12 bolt, Kauffman 461. |
True, so does being paranoid
Rushing, complacency, and eyes/mind not on task.
Jeff |
I was under my old 97 blazer years ago to change rear shocks, seemed awfully roomy under there. Then I realized the spare was gone. I never heard or saw a damn thing, I hope nobody behind me was hurt. Absolutely no clue where it went. Those cables rust out pretty quickly.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
I agree....mine gave me fits trying to drop it after it lived there for 15yrs! It now lives in the bed, tethered to a lug with a cable and a padlock!
Jimmy M 68 GTO |
This past winter was big project on my ride including all suspension and exhaust. Multiple times putting the car up on jack stands, some days the prep to get stands set correctly and where I knew it was solid would take me more than an hour. I do the full body shove test on it too to make sure it ain't going anywhere!
Could have been a Ford Exploder. You wouldn't have had to jack it up, because it would be laying on the roof with four wheels nicely exposed and pointing skyward. You could have changed the tire very easily that way.
#38
Safety is one of the most overlooked things but so often overlooked
#39
cheby and gmc HAVE terrible spare tire hanger and release mechanism ,more than once I have had the release mech not let loose after following the directions, the cable gets loose and all of a sudden the lock releases and the tire / wheel falls, the first time it landed on my arm,couple of xrays and nothing broken,2nd time I put blocking so it couldn't fall far, a good thing, AFTER that spare goes in the back
JIM |
