#101
Jeff |
#102
Man, I love that red color!!
#103
Thank you. Yes I’m a fan of red. Picked this color as it matched the interior the closest.
Thecoatingstore.com is where I brought all my paint from the epoxy to the Clear. Urekem paints.
Jeff |
#104
Set up with new tires and wheels
Jeff |
#105
Looking real good Jeff
Sent from my SM-T585 using Tapatalk
Wow!
#107
Very Nice!!!
1965 Pontiac 2+2 421 HO auto 1967 Pontiac Grand Prix 428 4 speed- sold 1968 Firebird 400 auto - sold 1967 Bonneville Brougham 2 dr. hardtop. 1969 AMC Rebel SST wagon-sold |
#108
Very nice !
#109
Bloody awesome
#110
64 Cat
Your car looks wonderful. Just one question, how is the ride with all the new suspension? Does the new sway bars tend to give it a stage coach ride?
#111
It rides and handles like a dream. Never rode in a stage coach so wouldn’t what to compare it too. I do know I can hit a curve at 60 and it hugs the road. It’s very responsive.
Jeff |
#112
Break in day
Got her out yesterday and put Two hundred miles on her. Drove wonderful. Handling was A1.
Jeff |
#113
Looks great..nice stance too. The only thing I would tweek....would be those tail pipes. Tuck them up. But that’s just me.
#114
Very nice ride! Just driving down the road, swaybars shouldn't affect much of anything (on straightaways). On turns different story but basically help to keep the car "flat".
#115
I think it looks badass! Great stance, awesome Red paint! I know it turns heads going down the road. Enjoy!
#116
Cat looks fantastic Jeff!
Joel |
#117
Upgrades
Finally got 500 miles on the Cat after all the carburetor problems. The rebuilt Carter 3326s had a flat spot right off idle while cruising down the road in all gears. Had the top off six times in one afternoon. Drove it the final miles to get it broke in and ready for first oil change.
Pull gas tank because of a incorrect read on the sending unit. Brand new unit when installed. While the tank was out I installed a vent and return fitting. Because I’m going efi. Ran a new 3/8” steel line back to tank for return line. Installed a Tanks Inc. vent/ rollover valve next to filler cap. Drilled and tapped a 1/2 Npt for temperature sensor for Fitech EFI. Drilled 7/8” hole in Exhaust and welded a weld in O2 bung. Installed a Fuel Command Center 2.0 next to battery ran line through the fender. Wired up a relay for the fuel pump. Installed the Fitech unit and finished all wiring. Primed fuel system and checked for leak. Then setup ecu for my motor and fired it up. Warmed it up to operating temperature and shut it down. Setup IAC Steps and started it again. Ran system in garage. Then took it for my first test after 500 miles oil change was done. I’m very pleased with this system it woke up the beast in my engine. Ran strong, throttle response is amazing. No jerking or jumping in any gear like when carburetor was on it. I’ve got over 400 mile on the Fitech Go Efi 4 600 system and wish I had done it sooner.
Jeff |
