Cam for cruise in and occasionally strip
455. 9.4:1 compression 3:42 gears Found this cam on offer up think it will work? 3315B/3316B HR 112 +4.0.
281 in. 287 ex. 230in 236 ex @ .050 lobe sep 112. Lift 510 in 520 ex. Custom ground comp Last edited by rascal455ho; 10-17-2018 at 05:09 PM. Reason: Add picture |
Should work REALLY good.Tom
Is that a roller?
Hydraulic Roller
Make sure you use Comp roller lifters. By most reports they are the only ones with the oil provisions in the correct place.
I have a similar cam in me KRE headed 455. Just slightly larger with faster ramp lobes.
Even up at 5000 feet it makes 13” of vacuum at warm idle, doesn’t buck or sputter at low speeds and has a noticeable chop to it. I think that cam in your application would be quite good!
They are XE hydraulic roller lobes custom ground with a 112 lobe separation.
Page 21 here: http://www.compcams.com/Technical/Ca...terCatalog.pdf The "B" after the lobe number is a roller cam lobe suffix code relating to the journal diameter. .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 10-17-2018 at 09:55 PM. |
It came with lunati lifters , scorpion race rockers and a summit 9 key way timing chain .
All new
This is the cam I am running with my 467. Seems to work well..
1967 GTO, 467 roller motor, e heads ported, tremec T56 magnum 6 speed and 9" done. EZ EFI 2.0 with FAST dual sync distributor and separate nitrous system done. Track is at 4300 ft elevation. so far a best of 11.95@116. Suspension now getting dialed in...tubular front a arms with dual adjustable coil overs HR Parts n stuff rear bar and whole car lowered 3 inches.. |
4/7 swap. 👍
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
Do a search for hyd rollers not pumping up on here. There is an outline for modifying the block. Unless your going to do that block mod I wouldn’t chance the Lunati lifters.
So are you running 455 round port ho heads, and if so what year?
Also are you running Exh Manifolds?
Thanks . I will check on lifters . No round port heads
Pokey that looks like a fun driver
I run the Lunati lifters in my 455. If I had to do it over again, I'd get the new Comp lifters. These do clatter slightly at idle when the car warms up and the oil pressure drops to about 15psi. These really need to see about 20 psi to keep quiet and continually pumped up. Off idle, they're fine and I haven't had any issues with them.
If your engine keeps a bit higher idle psi, they'll probably work well for you. If not, I'd consider the purchase of the comp lifters as suggested.
I have the comps and mine clatter too though. I think they have need to be tightened an extra 1/4 turn.
Could go the hybrid route with solid rollers.
Still going to be using chevy lifters!Tom
